Qcad Shading of Hatches
I am trying to reduce the appearance of both solid and pattern hatches. I tried to reduce the Alpha in the Properties Editor from 255 down to 50. This reduced the intensity in Model Space but no change in Paper Space. I tried printing from a .PDF but it still printed with full intensity. Is there a setting or other work around to help me.
I’m using Win 10 Home.
Thanks,
Paul.
Change the colour of the hatch? to (for example) light grey or any other shade you desire…
alpha behaves (for me) the same as you have described
Please attach your file. Note also that a solid black fill with Alpha 50 might still be very dark when printed depending on printer and driver. Did you try alpha of 5? Also, what is the result when exporting to PDF instead of printing? What is the result when printing the PDF?
I think that I can replicate this with ‘Prevent white on white / black on black display’ turned on.
It is common to use a black background when designing in Model-Space.
Then rendering Black lines as black on screen doesn’t make sense.
A page is typically white and color correction is usually applied to avoid white on white.
We tend to see many third party drawings using a white pen.
A black fill on a black background in Model-Space doesn’t fades at all.
It is always fully white.
But it is shaded just fine in Paper-Space in full color mode.
In both Grayscale and B/W mode it is fully black.
Logical that it is or Black or White in B/W mode but for Grayscale that seems incorrect.
This is reversed for a White fill on a black background what is shaded just fine.
But in Paper-Space its is fully black in all 3 modes.
At application level we can prefer a white background.
Note that this is not stored in a drawing file and it might just be different at our side.
Then the color correction kicks in for white on a white background.
Assuming that your paper color is set to white there is no difference between Model-Space and Paper-Space, white is then always fully black.
Attached a file with some examples.
Black, White and Red fills in shades 255-127-63-31-15
Paper color is white.
Experiment with this changing the 2 color correction preferences, using a black or white background and for the 3 color modes in page layout.
In total 18 different states … :wink:
ShadedHatches.dxf
In general, it appears that the correction for black (white) on black (white) kicks in before any shade is applied, and that grayscale values ​​are also based on the color of the object before shading.
It get more complex or even fuzzy for the same fills in the attached file but then in a Block and a Block-reference on a certain layer. Then it also depends on the Block-reference layer color, the Block entities their layers colors and the color property like ‘By Layer’ or ‘By Block’ or a custom one.
Further on if defined on Layer ‘0’ and a global preference.
For an entity in a Block-definition it is unclear to me which color is meant, a Block-definition itself has no color attribute to inherent.
The same is true for the other attributes or ‘General Properties’.
Thanks, bug report at:
