I just downloaded the Trial version, which is all I need for now, on an Intel powered Mac. The web based download instructions are to remove the Trial widget. The Trial Widget does not appear on my list of widgets. Does this mean it has already been removed or do I need to do something else?
The trial version of QCAD is a fully functional QCAD Pro version.
Only limited in session time and in the number of started sessions.
Printouts or exported PDF may include a watermark.
QCAD/CAM trial has a limitation on generated toolpaths.
Typically you see the Trial Widget at the bottom right with the buttons ‘Buy’ and ‘Remove’.
Also see menu Help .. About, the title would be ‘QCAD Professional Trial’.
Otherwise that would read ‘QCAD Community Edition’ (CE) and a Trial Widget is no longer included.
Hitting ‘Remove’ would display a list of files to remove for reverting to the CE version (e.g. Windows).
Removal instructions can also be found in this forum topic although not updated since 2017.
