I have been buying QCAD Pro for several years, to support a program with an open-source base, and I use it in my work as an architect (QCAD [versione], macOS on a Mac with Retina display). QCAD has grown a lot, and I think a few more steps on usability and interface are what it needs now. For better or worse, the interface counts as much as what a program can do.
The three points that would change my workflow most:
- Island detection for hatches. At the moment I have to create a polyline for each hatch. A “Close” command available from the Property Editor would also help; “Hatch from segments” works only in a subset of cases.
- Freezing layers per viewport, rotating a viewport, and printing several layouts at once.
- A list of the inserted images, showing any missing ones, together with a “reload” command and the option to set image resolution when exporting to PDF.
Other smaller points:
- Using Alt to switch Move/Rotate/Scale to copy mode. Removing the confirmation dialog is very useful, but hidden in the preferences; setting the command to “copy” and then the number of copies to zero from the keyboard works, but is not intuitive.
- Ortho works with Alt while it is held down, which makes it awkward to type a distance at the same time; a toggle (like F8 in AutoCAD) would help. The same for snap (like Ctrl in Blender).
- An easier way to align hatches with walls, not by eye.
- Snap precision: it sometimes feels imprecise, perhaps because of the Retina screen. The range can be set in Application Preferences > Graphics View > Behavior; a “response time” setting would be useful, since sometimes I click on one point and the insertion point lands on another.
- Isolating a layer, for example to make hatches quickly.
Many things already work better than in other 2D programs: the stability with images; the interactive Scale command, where the origin can be moved while seeing the result, and 2D scaling; the two-key aliases without Enter, similar to FreeCAD, which become faster after a while; the many useful scripts in the menus (duplicate and zero-length lines, flatten to 2D, Paste Along Entity, polyline simplification); the Selection Filter and the Property Editor; Offset with its options and automatic focus on the distance field; Trim in its variants, once the logic is clear. Block management is so fast that it becomes almost dangerous, because of the risk of overwriting a block by accident: grouping blocks into families, selecting the matching row in the Block List when an instance is selected in the drawing, and ideally a preview would make it even better. It would also be useful to start move and scale (with copy) directly from the grips, as in other CAD programs, and to copy the properties of a selected object onto others.
One question: is there a “select previous” command? I could not find it.
Thanks to Andrew and to everyone who contributes.
Daniele Rossi
