Hi everyone!
Qcad version: 3.21.3.0 (3.21.3)
Windows 10, 8 GB RAM, 932 GB HDD, 238 GB SSD, NVIDIA GeForce GTX 1650 (4 GB), Intel(R) UHD Graphics 630 (128 MB) (Sorry, I have no idea which of these informations are important.)
I know that too large files are common topic here, but I don’t know how to solve this problem (if it can be solved at all).
I created a probably too large (31 MB) dxf drawing in Qcad put together from about 1700 drawings (also created in Qcad) of an archaeological site. It took Qcad forever to open it every time (5-10 minutes), and it froze many times, but so far I could edit the drawing. The problem is that now it is just unable to open it. As I read the forum, I understand that it might be a too huge file for Qcad to handle.
Earlier I wanted to export it as a PDF, but it is impossible, because there are too many and too thick lines in a very small area (the objects are aligned with reference points - EOV coordinates), so I use “Screen-based Linetypes” to see every object properly.
Bitmap export also would be fine, but it froze almost every time I tried. I only have one png file saved, but it is not the final version.
I tried to open it with LibreCad and Qgis, but not all the information and line properties are transfered, and I do not want to edit it again.
So my question is that I created this drawing all wrong? Qcad is not suitable for creating that kind of drawing? Should I use Autocad instead? Or is there any chance to open and save this drawing in a bitmap file somehow?
Here is a link to the files: Unique Download Link | WeTransfer
Thanks in advance,
Edit
