I am running in my MAC Catalina 10.15.7 and 3.27.1 QCAD. All layers work fine except when I enable a layer with a JPEG drawing to be used as a background. When the JPEG layer is visible the other layers will only become visible while I hover my mouse over them.
Is there a way to make the JPEG layer to be allways on the background? The JPEG layer is a Google map that I use as reference for the other layers over it.
Hi Andrew, I followed your suggestion, but it still not working. I have only this layer selected which is a JPEG file, I am able to click on it and select modify and send to back, when I make another layer visible I can see the other layer on top of the JPEG layer and as soon I move the cursor over the cad drawing the only layer I see is the JPEG, however when the cursor hovers the other layers it will show correctly as long as the cursor is positioned over that specific layer.
Hi Husky - I locked all layers and now it works as I wanted. Thank you for pointing it out. I was under the impression locking the layers was optional apparently not. Can I lock only that one layer instead locking all layer? Sorry if I ask a simple question. Thank you
If you lock all layer then you can’t work on the drawing anymore. Just lock the layer which contains the jpg’s (and only jpg’s!) and it works like a charm …
