Hello
I have little “big” problem:
Use dwg2svg tools with batch file(SH) to convert MANY files DXF to SVG. ![]()
Environment: Server linux centos 7
Command loop execute:
./dwg2svg -platform offscreen -g -no-show -recompute-dim -x 4096 -y 2160 -outfile=“${filenameSVG}” -force -s 1:1 -c 10 -preserve-geometry -inkscape -unit=mm “${file}”
(These setups derive from many conversion tests done on dxf drawings that I have as examples from the design and modeling department)
Problem : print debug info ![]()
Solved: add Before command export QT_LOGGING_RULES=“*.debug=false;driver.usb.debug=true”
But another problem
tool print to video info conversion:
"QCAD version 3.22.1
Options:
Unit : mm
Inkscape Tags : true
…etc etc"
DAMN! OUCH!
Why?
I thought that was enough "./dwg2svg -platform offscreen "!!!
Since I have to convert many files I would like to have the stdout empty and print only the number of converted files through the script.
Isn’t there a silent mode for the tools?
Is there a trick (like I did for the debug info QT_LOGGING_RULES) to insert to have no info on the screen?
Thanks!
