Software:QCAD Pro 3.22.0.0
OS:Mac Mojave
Hello.
I have some questions about the dimension text.
When i open a dxf file in QCAD and select japanese fonts, only the dimension text remains garbled.
But the multitext part is not garbled.
And it is garbled even when I export PDF from QCAD screen.
However, there is no garbled character when exporting PDF from command line tool.
use command:
dwg2pdf -l -a -k -fs standard Arial -paper=A3
I can not edit the text by double-clicking this Dimension text.
Dimension text has been rotated.
Is this a QCAD specification?
(Im expecting an “autocad_ss.png”)
Thank you.
