[Solved] Debian 12, Wayland, Can't start after installation
I installed qcad-3.28.2-trial-linux-qt5.14-x86_64 in Debian 12 Wayland KDE
But it shows nothing after I click the Qcad icon.
I tried to start from terminal:
y@43s-1:~/opt/qcad-3.28.2-trial-linux-qt5.14-x86_64$ ./qcad
QCAD version 3.28.2
07:21:48: Debug: loading plugins…
07:21:49: Debug: RDwgPlugin::init: trial
07:21:49: Debug: RProScriptsPlugin::init: trial
07:21:49: Debug: RTracePlugin::init: trial
07:21:49: Debug: loading static plugins…
07:21:49: Debug: Renaming old unversioned config file from ‘/home/y/.config/QCAD/QCAD3.conf’ to ‘/home/y/.config/QCAD/QCAD3_old.conf’
Warning: Failed to load client buffer integration: “wayland-egl”
Warning: Available client buffer integrations: ()
Warning: No shell integration named “xdg-shell” found
Warning: No shell integration named “xdg-shell-v6” found
Warning: No shell integration named “wl-shell” found
Warning: No shell integration named “ivi-shell” found
Warning: Loading shell integration failed.
Warning: Attempted to load the following shells (“xdg-shell”, “xdg-shell-v6”, “wl-shell”, “ivi-shell”)
And it stops here.
What might be the problem?
Thanks.
Yen
Can you try to start QCAD with:
./qcad -platform xcb
For more information on this, please refer to:
Bottom line, your system likely tries to enforce running QCAD and other Qt apps using Wayland which is not recommended.
Thanks, Andrew, that solved the problem. It works perfectly now.
