Current behaviour: ATTDEF text height and angle changed when you open and save a DXF file when text start(10,20,30) is different from alignment point(11,21,31)
Expected behaviour: ATTDEF text height and angle should not change when saved
Perhaps malpractice but probably still a bug, the prompt text was a single space.
IMHO this should not affect angle and size.
With a prompt starting with a space the file is saved/opened correctly.
I never told you to use white spaces as a prefix! I would suggest to use solution one without the prefix white space. BTW - it is not a workaround! If a QCAD tool is used as intended it will work.
