section lines
Is it possible to insert a Section Line into a drawing - a line with a symbol at either end to note another section diagram?
QCAD has not a tool for that but it is easily achievable. Design the section line with those symbols, create a block and use it in your drawing. You can insert it as many times as you like, rotate/flip and if that still doen’t covers all possibility explode and stretch it.
Thank you for the prompt reply. I’ll give your suggestion a try.
