script bindings not available for qt 5.15.9
Running on MACOS 10.15.7 Catalina with Xcode 12.4.
Downloaded qcad from GitHub - qcad/qcad: QCAD - The Open Source 2D CAD. QCAD is a cross-platform CAD solution for Windows, macOS and Linux. It supports the DXF format and optionally the DWG format (through a proprietary plugin)..
Followed the instructions at QCAD - QCAD .
Qmake gave the following error message.
~/cad/qcad-master % qmake -r CONFIG+=ractivated
Reading /Users/admin/cad/qcad-master/src/src.pro
Reading /Users/admin/cad/qcad-master/src/3rdparty/3rdparty.pro
Project ERROR: Script bindings not available for Qt version 5.15.9. You can add them to src/3rdparty/qt-labs-qtscriptgenerator-5.15.9 or use another version of Qt.
I would not like to use another version of QT.
How can I find another script bindings?
Can’t help you much, this are the supported platforms:
I notice that all the script generator files are the same so I created one for 5.15.9 which solved the problem.
how do you created one for 5.15.9 ?
can you tell more please ?
I think I simply copied one of the others and renamed it. Look at the others and you’ll see they are all the same except their name.
