QCAD Professional - Version: 3.32.8.0 (3.32.8); Win11; Dell Precision 3580
I have used the ripples hatch (as wood) in a drawing on an older QCAD version.
If I select the “ripples hatch” and check under Property Editor it lists RIPPLE in the current version as the last one in the list of hatch patterns. However, if I change the layer or color, the hatch “disappears”. I can copy the original object with the ripples hatch though, but the moment any other attribute is changed the ripples hatch is no longer shown and clicking inside the object does not select any hatch.
Is there a way to edit the hatch pattern system file to insert or reactivate the “ripples” hatch?
Hi
A used Hatch pattern is stored in the drawing.
It has then the property ‘From Entity’ = Yes.
When you created this Hatch the pattern was installed on your system.
But somehow it seems to be removed.
Such patterns/line-types/fonts are then listed as last in the combobox.
You can’t fully edit a Hatch with an orphaned pattern.
Mostly because its pattern is stored as applied and not in its virgin form.
The stored Hatch properties are only listed to re-generate the Hatch from an installed pattern.
The solution is to re-install its *.pat file under the pattern folder:
…\QCAD\patterns\imperial (and/or metric).
It was a custom pattern created by John Hyslop, see:
This issue is somehow addressed for an upcoming release (>3.32.9)
Not really a bug fix because the solution for orphaned patterns can have major consequences.
<Ripples> is a complex and quite demanding pattern with 130 line definitions.
As is: Highest cloning load: 27 … Total load: 1609 / ‘Tile’.
Or more simply said:
It requires 1609 parallel lines to repeat the pattern in an adjacent ‘Tile’ of 1" by 1".
And already 27 parallel lines to only repeat a single most demanding line segment(s).
Note that a ‘Tile’ has 8 adjacent ‘Tiles’ and that may require up to 130 + 12872 parallel lines for an area of 3" by 3". Already 13k parallel lines to render the 1170 segments in those 9 ‘Tiles’.
At some point the Hatching engine can simply time-out.
You may read that <Ripples> was created with a tool that I wrote called Tile2Hatch.
It exploits special techniques to code a pattern as stable as possible for the use with QCAD.
All because how the QCAD Hatching engine is implemented …
… All because patterns are defined as endless line with a custom line-pattern.
The above is one of the reasons that Tile2Hatch was never released in public.
QCAD can simply not cope with very complex patterns that can be generated by Tile2Hatch.
Or with some of those that can be sourced on the web.
On changing the orientation the ‘custom’ stored pattern was deleted and regenerated from the virgin pattern. This has little to no influence on its stability in the long run.
But storing this as custom in a file can have a major influence.
It was only stored once as such before.
Now a new scale and orientation is calculated and applied relative without that it can rely on virgin pattern definition.
This scaling an rotating don’t exploits the special techniques and it may become unstable stored as such.
As always the most important advice is to keep your Hatching origin near your Hatch entity.
But this is counteracted by storing it as custom in a file.
Hatches far from the origin will loose definition accuracy after the decimal point quickly.
Bottom line:
The fix will work for simple patterns but I predict that it may corrupt patterns from another source than the easy patterns included with QCAD.
