Restrict Orthogonal
Hello:
I am new to QCAD having switched from draftsight. Is there any way to make Restrict Orthogonal stay active until turned off manually. I tried Lock snap but that didn’t work. It turns of by it’s self after 1 or 2 commands. In draftsight orthogonal will not change state until switched manually by the user. OS: Win 10 QCAD ver: 3.27.1
Thank you
Hi
Try keyboard shortcut EO :+1:
Try this, LI to start line command then after you pick start point type EO, the lines are now drawn orthogonaly
Hint if you also hit spacebar you can type in the length
PS also see this topic
