Remove translation flnes from source (if unused)
OS: Every Arch Linux based distribution
Version: Arch Linux - qcad 3.32.6.0-1 (x86_64)
Arch is building this project with system-wide Qt6 (probably unsupported).
I notied that source has translation files at qcad/ts at master · qcad/qcad · GitHub which is duplicating with Arch Linux - qt6-translations 6.10.2-1 (any) And build passes if they are replaed with system’s one.
Would you remove, (or set to build *.qm from *.ts by default including qcad’s one) if possible?
