Reading DXF-file with a Multileader block doesn't show the block
QCAD Version: 3.32.9
The DXF-file is programmatically created with Python using ezdxf the best Python library in the world for creating / changing DXF-files. It’s fully OpenSource and tries to be as close as possible to the “DXF standard”. It’s also a great place to learn a bit how DXF works. Learn more at GitHub - mozman/ezdxf: Python interface to DXF · GitHub and Quick-Info — ezdxf 1.4.4 documentation
To make things easier, I created a DXF template with different blocks and add them programmatically when needed. Opening this DXF files in BricsCad or AutoCad shows the intended drawing.
ezdxf also supports creating a multileader with a block attached to it. I’m using this as a BOM balloon which I add by adding a point where the leader starts and a point where the leader ends. Then the block is automatically attached by ezdxfwith the right DXF codes.
Opening the DXF in QCad however doesn’t show the BOM balloons but got a bunch of warnings on the console:
14:17:02: Debug:    >>> RDwgMLeaderImporter::import
14:17:02: Debug:    "RDwgServices::printErrorStackTrace: Not opened for read"
Warning:  RDwgImporter::importEntity: entity NOT imported:  0x560472fa3000
Warning:  RDwgImporter::importEntity: entity NOT imported:  0x560472fac7a0
Warning:  RDwgImporter::importEntity: entity NOT imported:  0x5604763f9930
Warning:  RDwgImporter::importEntity: entity NOT imported:  0x560476d3c840
Warning:  RDwgImporter::importEntity: entity NOT imported:  0x5604747f21e0
Warning:  RDwgImporter::importEntity: entity NOT imported:  0x5604710f6630
I have created a very basic DXF file with only the BOM balloon in it and attached it.
my_template.dxf (1.2 MB)
I can confirm that the MULTILEADER entity type is currently not supported by QCAD.
Thanks for the fast response! Any chance this will be supported in future versions of QCad?
I tried to manually move to a normal leader which is displayed, but the block seems to be exploded and not connected to the leader anymore.
But it shows the BOM balloon which already helps a lot.
<-edit>
Was a bit to fast because the normal leader is just what it is: a leader. So the block can be somewhat attached but is will stay disconnected. I have to use the MultiLeader unfortunately.
</-edit>
There are no plans currently for adding multi leader support in QCAD. This might change in the future if there is more interest for this.
