QCAD Version: 3.7.0
wrong radius.dxf (96.1 KB)
I have attached my drawing file (DXF/DWG)
I have a rectangle 460x230mm but the longer side have a radius of 3537mm.
When I do the radius the highest point is not in the middle!
Why is this happening?
QCAD Version: 3.7.0
Why do you think the highest point is not in the middle? How do you verify this?
I’m asking because that’s very likely the problem and there might be a solution, depending on your method.
Verified, the highest point is coinciding with the middle point.
Why: The arc centers are at X-zero, the vertical edges are at X-230 and X+230.
The highest position in Y of a circle with radius 3537 and center at (0.0, 230.0) is located at (0.0, 3767.0) and the arc in question is a part of such a circle and is symmetrical in regards with the Y-axis.
Q.E.D.
If you look at the DXF I attached I have put a line across the top where the highpoint of the radius should be, but the are is highpoint to the left of centre.
If your verification is based on the visual appearance of your drawing, please post a screenshot as you might see something different that we do (depending on your display preferences).
Because of the limited resolution of a display, the top arc and the horizontal line may look to intersect at the left and at the right of the Y-axis.
Or they seem to be co-linear for a small portion in the middle.
The difference for the representation of both entities on screen is there less than 1 pixel.
In reality the difference becomes very small with a minimum of zero in the middle.
Perhaps the real intersection point of those two at vector level is more clear.
