QCAD 3.17.2
QCAD 3.17.2 adds new alternative projection types to the isometric projection tool. Multiline texts and formatted complex texts are now exploded into single line, simple texts. SVG export of multi-line and formatted texts has been improved. A new tool to copy (duplicate) blocks has been added.
The QCAD command line tools dwg2bmp, dwg2pdf, dwg2svg and dwg2maptiles come with a new -layer switch to export a given set of layers only.
QCAD/CAM 3.17.2 adds new post processors for EMC2 and Mach3 controllers.
A complete change log is available at:
Update instructions for QCAD Pro or QCAD/CAM users can be found at:
