Post Processor
Hi I need help adjusting the post processor to get my touch off z axis to work.
It works in open builds and Fusion 360 so it must be script.
I have a Gen 1 JD Garage machine running on GRBL . I looked at adjusting the scripts under the post processors file area but there a good chance I’ll mess it up.
But if someone has one already for the z axis touch off that would be great. I attached the general settings from JD garage for GRBL settings
Window 11
Current Qcad/Cam Version
Post processor GRBL mm
Thanks Ian
GRBL Settings.xlsx (9.25 KB)
These are all physical parameters of a CNC driver (‘GRBL’ based)
In most cases they are unrelated or not needed for CAM and/or simply not influenced by CAM.
E.g. CAM FEED-rate is the intended velocity in any direction in the XY plane.
The decomposed velocities in X and in Y must comply or are limited to $110 and $111.
At the QCAD/CAM side it doesn’t matter if you enter FEED = 1.000.000 mm/min (60km/h) for a certain profile.
5 meters per minute is starting to sound pretty fast for a DIY setup.
Max step-rate would 40 x 5,000 / 60 = 3.33 Khz or 10 x 5,000 / 60 = 833.33 hz and really not that high.
X resolution = 0.025 , Y resolution = 0.1 and those are pretty limited.
It seems to be a fairly fast setup with low resolution.
This doesn’t say anything on accuracy and repeatability.
I have no explanation for the difference in resolution, it relates to the drive-trains, drivers and axis construction.
Maximum acceleration is a less well understood and neglected parameter set at about 1/10G.
The smallest circular motion at FEED 5000 would have a radius of 6.94mm …
… Otherwise FEED drops to comply with accelerations.
Homing is to ensure that the physical position of the setup matches with the logical parameters of the driver.
In the XLS is said that: ‘$23: Setting is not used so the setting doesn’t matter’ … It does matter :exclamation:
Typically first UP in Z (to be safe) then in XY.
Homing an axis ends at a limit switch or you have some other sort of feed-back of the actual position.
You can place your work-piece anywhere in XY.
Next step is to Zero your work parameters on the work-piece.
Best practice is first in XY and then in Z.
Using QCAD/CAM it is mandatory that this correlates with the drawing origin.
Touch-off is the process of Zeroing Z at the top of your work-piece.
QCAD/CAM assumes that Zzero is the top of your material, actual cutting is in -Z.
A post processor for QCAD/CAM converts CAM-entities to motion instructions in the specific G-Code dialect.
Typically this doesn’t concerns: Homing on power up, Zeroing XY, Touch-off or Zeroing Z.
Nor does it concerns: An auto tool changer followed by an automatic tool length compensation.
