I needed to access some older QCAD files and saw that the dimension entities had lost their arrows and text values (completely missing. With an older QCAD version (and OS), they appeared correctly.
OK, I downloaded the latest Linux version (3.31.2.0) and my file was shown correctly.
However, I wanted the community edition, so I removed the 10 plugin files as per the “Remove” instructions. Then the dimension fault appears.
