Hello together,
we´re searching for a new simple CAD solution, for creating some production draws, but we have some obstacles which I try to find a solution.
First point is that we need the function to create a draw from an XML-file which contains the dimensions of an exterior rectangle with inside the rectangle a specific count of vertical and horizontal bars. These bars have (dependend of the bar-type) specific connectors which should initially automaticall drawed:
I think it should be possible to work with scripts to achive this requirement.
The next problem we have is, that we want to draw just a single line and get the bar-type automatically drawed (afaik in Autocad there is a multi-line option and I hope to find a similar solution here).
With an auto-trim function we need the possibility to fit a bar on one side to the frame and if we move to a crossing bar we need a specific “closure” of the bar.
There I have no idea how to get this solution.
I hope the explanation of my request is my request is comprehensible and someone can give me some hints if (and if yes how) it´s possible to solve these problems.
Thanks a lot in advance.
BR
Christian
