Menu Font Size
Hi
I’m using version 3.25.2.0 running on Ubuntu 18.10.
My problem is that the menu fonts are extremely small. I can use QCAD on my laptop screen (13") but if I move the QCAD session to the 30" attached monitor the menu fonts are unreadable.
How do I change the font size ? Screen shots attached below
David
I’ve just been poking around the install directory and found the file opt/qcad-3.25.2-pro-linux-x86_64/qcad
This file contains the lines
# breaks on some systems:
# disable if QCAD renders too large
QT_AUTO_SCREEN_SCALE_FACTOR=1 LD_LIBRARY_PATH="$DIR" "$binary" "$@"
If I comment it out, QCAD won’t start. If I increase it to 2 there is no difference. If I set it to 0 then the menu font is fine but the toolbars are unusably small.
Am I looking in the right place to fix the problem ?
and changing it to
QT_SCALE_FACTOR=1.5 QT_AUTO_SCREEN_SCALE_FACTOR=1 LD_LIBRARY_PATH="$DIR" "$binary" "$@"
Makes the UI scale OK on the large external screen but the menu small (and largely non functional i.e. menu can be clicked but does not show the child items on some menus, others have huge amounts of blank space before sub items etc)
Am I on the right track ?
Changing it to
QT_FONT_DPI=96 QT_SCALE_FACTOR=2 LD_LIBRARY_PATH="$DIR" "$binary" "$@"
Fixes the UI problems (all the widgets appear at the right size), and the menu fonts can be read but only a few of the menu items contain sub items when clicked.
So still looking for a solution here.
You can change the menu font size at Edit>Application Preferences>Widgets>Menu Bar. You’ll get a message saying you have to restart, but I’ve found that’s not necessary.
What’s about scaling the User Interface?
Used scale factor = 1
Used scale factor = 2
Can you not do this for the tool matrix?
Also, can you change the font type for the menu bar / tool matrix?
No, not using Qcad settings, but you can by using my Qcad Theme Designer - Qcad Theme Apps - QCAD Script Programming & Contributions - QCAD Forum - enable Font Overrides, the menu bar and items are on Fonts 1 tab and Tool Matrix is on Fonts 2 tab.
Hi, I tried theme designer today, enabled font override and checked BOLD everywhere in all tabs, but the tool matrix item names still remain the same, e.g. they are not bold. Are these item’s font properties unchangable?
Are you sure that you have the Bold check box ticked for Tool Matrix on the Fonts 2 tab…
…as it definitely works…
Absolutely. Notice that my tool matrix is set to list view. The category names such as Point did change to bold, but the i_tem names_ such as Single Point PO didn’t change to bold
I’m sorry, I misread your post, I was unable to find a way to change the items in the Tool Matrix.
@bob93 - I’ve finally found out how to change the Tool matrix list view item text (they are actually tool buttons). You can add the following to blank line 436 in your stylesheet.css file (make sure no extra lines are added)…
QTreeView#ToolMatrix QToolButton {font-size: 10pt; font-weight: Bold; font-style: Normal;
You can change the font height and style to suit yourself, font-weight can be Normal or Bold, font-style can be Normal or Italic. :slight_smile:
This is now included in the latest version of Qcad Theme Designer - Qcad Theme Apps - QCAD Script Programming & Contributions - QCAD Forum
I only now see this, but I don’t quite understand. Line 436 of my stylesheet.css file is not empty. This is what the file says from line 434:
QScrollBar::sub-line:horizontal
    width: 18px;
    subcontrol-position: left;
    subcontrol-origin: margin;
Can you give me another reference to find the part where I must place the code you gave?
It looks like you are using a theme that ships with Qcad, what is the theme name you are using ?
You can try adding the code at line 489 which should be empty if it’s a theme that ships with Qcad.
Yes, I’m using theme Heather (a copy of it to keep the original one intact). Line 489 in that file is also not empty, it says:
/ move all the vertical tabs down so first tab is not floating /
Let me post the whole file:
Heather theme
Created by Pete Vickerstaff
THIS FILE IS PROVIDED *AS IS*, WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THIS FILE OR THE USE OR OTHER DEALINGS IN THIS FILE.
Updates------
v1 - 13/01/21 - changed the background color of the graphics view title bar
                Groupbox and DockWidget title font now bold
                Changed the background color of any PushButton that has focus
v2 - 15/01/21 - QTabBar added. I missed these objects originally
v3 - 19/01/21 - Font colour changed to fix unreadable text in certain disabled elements.
                Disabled background lightened
                Other minor GUI changes
v4 - 27/01/21 - Fix to prevent text moving in Layer, Color and Lineweight option lists
                Also removed QMenu items for the same reason
v5 - 01/02/21 - RadioButton:hover changed to an icon.
                Code added to fix MenuBar item selected background.
                Fix for Version and Units text background display in FlexPainter dialog.
v6 - 24/02/21 - Tool Matrix widget header background colour changed.
                Full set of Checkbox and Radio button icons added.
                Tab bar and Tabs improvements.
                General graphical and colour improvements.
                Added a ToolButton checked state for on/off tool buttons
                 in the Reset, Options and Snap toolbars, possibly other locations.
v7 - 16/03/21 - Move  all the bottom tabs right so first tab is not floating.
                Bottom inactive tabs background fixed.
                Bottom inactive tabs font color made more visible.
                Tooltips section removed.
/*-----QWidget-----*/
QWidget
    background-color: #B7C4CC;
    color: #000;
    selection-background-color: #386B8C;
    selection-color: #fff;
QDockWidget, QDockWidget:title
    font-weight: bold;
/*-----QLabel-----*/
QLabel
    background-color: transparent;
    color: #000;
QLabel::disabled
    color: #6D6D6D;
/*-----QMenu-----*/
QMenuBar {
    background-color: #72A0BF;
QMenuBar:item:selected {
    background: #386B8C;
    color: #fff;
QMenu
    color: #000;
QMenu::item:selected
    color: #fff;
QMenu::item:disabled
    color: #6D6D6D;
/* Current tool icon in options tool bar */
QToolBar#Options QLabel#Icon {
    background-color: qlineargradient(x1:1, y1:0, x2:1, y2:1, stop:0 #C7D5DF,stop:1 #7A95A6);
    border: 1px outset #72A0BF;
    border-radius: 6px;
/* Tool bar button icons in options tool bar */
QToolBar QToolButton {
    border-radius: 5px;
/*-----QToolButton-----*/
QToolButton
    border-radius: 5px;
QToolButton::disabled
    background-color: #3a6f92;
    border: 1px solid #768995;
QToolButton::hover
    background-color: qlineargradient(x1:1, y1:0, x2:1, y2:1, stop:0 #F9FAFB,stop:1 #94A5AF);
    border: 1px inset #72A0BF;
/* checked state for on/off toolbar buttons */
QToolButton:checked {
    background-color: qlineargradient(x1:1, y1:0.545, x2:1, y2:0, stop:0 #92b9d3,stop:1 #2c536d);
    border: 1px inset #308CC6;
QToolButton::pressed
    background-color: qlineargradient(x1:1, y1:0, x2:1, y2:1, stop:0 #92b9d3,stop:1 #2c536d);
    border: 2px inset #72A0BF;
/*-----QPushButton-----*/
QPushButton
    border-radius: 5px;
    padding: 3px;
    min-width: 6em;
QPushButton::disabled
    color: #B7C4CC;
    border-color: #768995;
QPushButton::hover
    background-color: qlineargradient(x1:1, y1:0, x2:1, y2:1, stop:0 #F9FAFB,stop:1 #7A95A6);
QPushButton:focus {
QPushButton::pressed
/*-----QLineEdit-----*/
QLineEdit
    background-color: #99B0BF;
    color: #000;
    border: 1px solid #7A8E9A;
    border-radius: 3px;
QLineEdit::disabled
    color: #B7C4CC;
    border: 1px solid #051a39;
/*-----QTextEdit-----*/
QTextEdit
    color: #000;
    border: 1px groove #3A6F92;
    border-radius: 3px;
QTextEdit::disabled
    color: #B7C4CC;
    border-color: #051a39;
/*-----QComboBox-----*/
QComboBox
    border: 1px solid #86A2B3;
    border-radius: 3px;
QComboBox::disabled
    color: #B7C4CC;
QComboBox:hover
QComboBox:on, QListView QAbstractItemView:on
    color: #dbe8f0;
QComboBox QAbstractItemView
    color: #000;
    border: 1px solid darkblue;
    border-radius: 3px;
/*-----QGroupBox-----*/
QGroupBox
    margin-top: 20px;
    font-weight: bold;
    border: 1px solid #3A6F92;
    border-radius: 3px;
QGroupBox::title
    subcontrol-position: top left;
    font-weight: bold;
QGroupBox::disabled
    border-color: #898988;
QGroupBox::title::disabled
    color: #898988;
/*-----QCheckBox-----*/
QCheckBox{
QCheckBox::disabled
    color: #656565;
QCheckBox::indicator:checked
    image:url(icons/checkbox-checked.png);
QCheckBox::indicator:unchecked
    image:url(icons/checkbox-unchecked.png);
QCheckBox::indicator:checked:hover
    image:url(icons/checkbox-checked-hover.png);
QCheckBox::indicator:unchecked:hover
    image:url(icons/checkbox-unchecked-hover.png);
QCheckBox::indicator:checked:disabled
    image:url(icons/checkbox-checked-disabled.png);
QCheckBox::indicator:unchecked:disabled
    image:url(icons/checkbox-unchecked-disabled.png);
/*-----QRadioButton-----*/
QRadioButton
QRadioButton::disabled
    color: #656565;
QRadioButton::indicator:checked
    image:url(icons/radio-checked.png);
QRadioButton::indicator:unchecked
    image:url(icons/radio-unchecked.png);
QRadioButton::indicator:checked:disabled
    image:url(icons/radio-checked-disabled.png);
QRadioButton::indicator:unchecked:disabled
    image:url(icons/radio-unchecked-disabled.png);
QRadioButton::indicator:checked:hover
    image:url(icons/radio-checked-hover.png);
QRadioButton::indicator:unchecked:hover
    image:url(icons/radio-unchecked-hover.png);
/*-----QStatusBar-----*/
QStatusBar
    border-radius: 3px;
QStatusBar::item {
    border-width: 0px;
/*-----QScrollBar-----*/
/*---Vertical---*/
QScrollBar:vertical
    width: 15px;
    margin: 18px 0 18px 0;
QScrollBar::handle:vertical
    border: 1px solid #d3d7df;
    border-radius: 2px;
    min-height: 20px;
QScrollBar::add-line:vertical
    height: 18px;
    subcontrol-position: bottom;
QScrollBar::sub-line:vertical
    height: 18px;
    subcontrol-position: top;
/*---Horizontal---*/
QScrollBar:horizontal
    height: 15px;
    margin: 0px 18px 0 18px;
QScrollBar::handle:horizontal
    border-radius: 2px;
    min-height: 20px;
QScrollBar::add-line:horizontal
    width: 18px;
    subcontrol-position: right;
    width: 18px;
/* remove border from dockable widgets */
QWidget#PropertyEditor,
QWidget#ViewList,
QWidget#BlockList,
QWidget#EcmaScriptShell QFrame,
QWidget#LayerList,
QWidget#LayerListPro {
    border: 0px;
/* make sure certain elements still have a border */
QTreeView, QListView {
    alternate-background-color: #72A0BF;
    border-radius: 3px;
QTreeView::item:hover {
    color: #fff;
QTreeView#ToolMatrix {
/* border in Application Preferences>General>Tool Settings */
QTabWidget::pane {
    top: -1px;
QTabWidget::pane:disabled {
    top: -1px;
    border: 1px solid #898988;
QTabBar::tab:top:disabled,
QTabBar::tab:top:!selected:disabled {
    border-left: 1px solid #898988;
    border-top: 1px solid #898988;
    border-right: 1px solid #898988;
    color: #898988;
/* move all the vertical tabs down so first tab is not floating */
QTabBar::tab:first:left,
QTabBar::tab:first:right {
    margin-top: 40px;
/* move all the bottom tabs right so first tab is not floating */
QTabBar::tab:first:bottom {
    margin-left: 10px;
/* VERTICAL LEFT TABS */
QTabBar::tab:left {
    border-left: 1px solid #3A6F92;
    border-top: 1px solid #3A6F92;
    border-bottom: 1px solid #3A6F92;
    padding: 12px 3px;
    color: #000;
    background: #B7C4CC;
    border-bottom-left-radius: 3px;
    border-top-left-radius: 3px;
    margin-right: 1px;
QTabBar::tab:left:!selected {
    margin-left: 3px;
    padding: 12px 3px;
    color: #666666;
    background-color: qlineargradient(y1:1, x1:0, y2:1, x2:1, stop:0 #898988,stop:1 #B7C4CC);
QTabBar::tab:left:!selected:hover {
    color: #000;
    font: italic;
    margin-left: 0px;
/* VERTICAL RIGHT TABS */
QTabBar::tab:right {
    border-right: 1px solid #3A6F92;
    padding: 12px 3px;
    color: #000;
    border-bottom-right-radius: 3px;
    border-top-right-radius: 3px;
    margin-left: 1px;
QTabBar::tab:right:!selected {
    margin-right: 3px;
    padding: 12px 3px;
    color: #666666;
    background-color: qlineargradient(y1:1, x1:0, y2:1, x2:1, stop:0 #B7C4CC,stop:1 #898988);
QTabBar::tab:right:!selected:hover {
    color: #000;
    font: italic;
    margin-right: 0px;
/* HORIZONTAL TOP TABS */
QTabBar::tab:top {
    padding: 3px;
    color: #000;
QTabBar::tab:top:!selected {
    margin-top: 3px;
    margin-bottom: -1px;
    padding: 3px;
    color: #666666;
    background-color: qlineargradient(x1:1, y1:0, x2:1, y2:1, stop:0 #898988,stop:1 #B7C4CC);
QTabBar::tab:top:!selected:hover {
    color: #000;
    font: italic;
    margin-top: 0px;
/* HORIZONTAL BOTTOM TABS */
QTabBar::tab:bottom {
    padding: 3px;
    color: #000;
    margin-top: 1px;
QTabBar::tab:bottom:!selected {
    margin-bottom: 3px;
    padding: 3px;
    color: #666666;
    background-color: qlineargradient(x1:1, y1:0, x2:1, y2:1, stop:0 #B7C4CC,stop:1 #898988);
QTabBar::tab:bottom:!selected:hover {
    color: #000;
    font: italic;
    margin-bottom: 0px;
/* Fix for Version and Units text background display in FlexPainter dialog. */
QObject#FlexPainterDialog QLineEdit#lineEdit,
QObject#FlexPainterDialog QLineEdit#UnitsLabel
    padding: 0px;
    margin: 0px;
    border: 0px;
    border-style: none;
    color: #000;
I’d forgotten that the Qcad themes are not a consistent length.
Search for “/* VERTICAL LEFT TABS */” and place the code in either of the two empty lines immediately above it.
BTW, the version of Heather you are using is not up to date, the latest version that has been shipping for quite some time is v8, you are using v7.
Done, but it didn’t work. Shouldn’t there be a closing bracket after “Normal;” or something like that? just a guess
Here’s what the block looks like. I made sure no extra lines were added, so there were two empty lines and now there’s only one above the code you gave me
QTabBar::tab:left {
    padding: 12px 3px;
    color: #000;
    margin-right: 1px;
Ooops, yes there should be a closing curly bracket } …
QTreeView#ToolMatrix QToolButton {font-size: 10pt; font-weight: Bold; font-style: Normal;}
…tested and working.
