qcad 3.32.6.0
Sudenly when i am going ta made a pdf its very slow ,been so a couple of months know
qcad 3.32.6.0
Please post one question per topic in the forum.
Please be as specific as possible in describing your problem and attach your files, so we can help you efficiently, thanks.
| Version: 3.32.4.0 (3.32.4) Webbsida: QCAD.org Byggdatum: Sep 4 2025 Revision: d3aa6db Qt Version: 5.14.2 Arkitektur: x86_64 Kompilator: gcc 5.4.0 |
Op Linux Mint Utgåva Linux Mint 22.3 Zena 64-bitar
when i press save as pdf at firtst the dialog appears with just the frame for about 5-7 sec ,after that the window appears but is unresponsive for about 10 seconds
This sounds more like a problem with the file dialog. Does this also happen when you use File > Save As…?
Yes it does
This would indeed indicate that there is a problem with the file dialog on your system rather than a problem with PDF export in QCAD.
You might want to try to disable the use of the system file dialog:
Edit > Application Preferences > File > Open/Save > [ ] Use system file dialog (uncheck)
