macOS Middle Mouse Button
With QCAD on linux mint (various versions of each) my middle mouse button pans (without keyboard use) as it should. With QCAD pro 3.29.6.0 on Mac OS 10.15.7 it displays all open windows instead (unless keyboard used). (Pan Gesture is enabled in App. Settings/Navigation, generic mouse with middle wheel/button combined).
How do you make it behave like the Linux version? I often need to pan and zoom while drawing with mouse only.
I’ve split this question to a new topic is it is not directly related to the other topic.
This is a preference of your operating system, not QCAD. QCAD never receives your middle mouse button click.
You’d have to change your macOS preferences accordingly:
Solved. Thank you.
In case anyone else is stuck on this, the simplest solution was Preferences/Mission Control/then disable Mission Control middle button setting in right hand box so it shows " - " .
