Lost Lead in Settings
If a toolpath is created with a Lead In setting, the toolpath is created correctly.
However, after opening the created toolpath for editing, the used Lead In settings are gone.
LeadInLostInCyberspace.pdf (81.2 KB)
That can indeed be a problem. :wink:
I can understand that the option Lead In/Out is not stored persistent between usage for new Profiles, between QCAD sessions.
But it should be updated for an existent Profile.
The thing is that the same dialog is used for both purposes.
For creation and for displaying and/or updating
It is still possible that parameters are stored as custom properties for the Profile.
Because they are required for auto - regeneration on export.
The best place to file a Bug report is: QCAD Bugtracker
An account there is not associated with that of the forum.
