Good Evening,
Although certainly not fair to compare CAD software, as each have their advantages and compromises, and I quite like the balance stricken by QCAD Professional (currently running 3.31.2.0, Windows 10), and the tools at our disposal within QCAD, as well as the Community, as represented within this Forum.
That said, I am genuinely curious about a difference in the on screen display of certain Linetypes in DWG (or DXF) files on different platforms / software, a difference that may well persist due to the technical limitations of the DWG (or DXF) file format.
I routinely create DWGs, generally R27 [2013] DWG Drawing [OpenDesign] (*.dwg), or the analogous DXF, or the newer R32 [2018] DWG / DXF, with Layers, and Edit Layers (YE), setting the Linetype to something other than “Continuous” (quite frequently “Hidden”), or alternatively, I set the Linetype explicitly, via the Property Editor (GP), for specific geometry (usually Lines / Polylines). Occasionally, I share such DWGs directly, with someone that (unfortunately!) uses another platform / software supporting DWGs, and the Linetypes (with some exceptions, i.e. the default “Continuous”) are not displayed properly. I also share such DWGs with my mobile device (Android), view them on Apps supporting DWGs, and Linetypes are also not displayed properly.
Perhaps even the default Linetypes available on QCAD Professional, or Linetypes in general (other than the default “Continuous”), are not an intrinsic feature of the DWG (or DXF) file format? Coincidentally, and on another note, I use Hatches (most notably with Pattern “ANSI31”, and “AR-CONC”), quite successfully, which seem to display just fine across different platforms / software supporting DWG (or DXF).
The Drawing that follows, contains, for illustration purposes, a Line from 2 Points (LI) - Line Segment (,S), of Length: 1, and with Linetype Scale: 5, the latter set explicitly via the Property Editor (GP), starting at the Origin in Model Space. This Line is Offset (with Distance) (OF) (Distance: 0.1, Number: 9), vertically, resulting in 10 parallel Lines (all with Linetype: By Layer and Linetype Scale: 5). Each such Line is then moved onto appropriately named Layers: Continuous, Dashed, Dot, Dash_Dot, Hidden, Center, Batting, ISO_Dash, ISO_Dot, and ISO_Dash_Dot (each of these Layers have their Linetype set via Edit Layer (YE) to the named Linetype). For good measure, on the right of the parallel Lines, I have also thrown in 10 Rectangles (Squares) with Size (RS), with a (random) selection of Hatch Patterns.
Test.dwg (20.8 KB)
On QCAD Professional, Linetypes appear perfectly fine, on another well known, and compliant viewer (released by the creator of the proprietary file format), the same Linetypes do NOT display the same as on QCAD (they all appear as “Continuous”, with exception of Dot / ISO Dot that disappear altogether). Surprisingly, all Hatches are displayed perfectly the same on both software. Oh the joys of proprietary file format “standards”!
Any thoughts, or feedback (perhaps also regarding how to maintain best compatibility), are greatly appreaciated, thanks in advance!
Relevant Settings (of the attached Drawing):
- Drawing Unit, Paper Unit, and Measurement System: Meter, Millimeter, and Metric, respectively.
- Global Linetype Scale: 1.
