Linetypes definition [SOLVED]
I am new with QCAD (3.24.0 Professional for Linux) for 1 week (Before I used DraftSight).
In some old plans, I defined as line types:
“TRACKS”: +++++++ (or “Rails” in French)
“BATTING”: SSSSSSSSS (or “'isolation” in French)
I see that these linetypes are well defined in the qcadiso.lin file.
With the pattern TRACKS (“+++++”) : no problem : it works.
With the pattern BATTTING (“SSSSS”) :
in some drawings, it works : the linetype “insulation” is well defined with the pattern “SSSSSSS”.
But in other drawings, the linetype “insulation” is empty (no pattern).
Why this difference ?
It seems to me that those drawings refer to the same .lin file
Thank you for your reply
Drawing files may contain their own definition of linetypes and override the linetypes defined in the .lin files.
You can reset these drawing internal linetypes using:
Misc > Modify > Reload Linetype Definitions
If you cannot solve the problem, please attach or send the drawing file.
Thank you very much for your quick response !
It works !
Is it possible to define new types of lines or must we limit to the predefined types ? (there are already quite a few !)
You can add new linetypes by adding new .lin files under linetypes/metric or linetypes/imperial of your QCAD installation.
awesome, it works perfectly!
how to indicate this topic as “SOLVED” ?
Edit you first post.
thanks,
