Hello, I need some information prior to forward a formal request to our purchase / license management dept.
Background: QCAD Pro will be installed on red hat 8 / 9 (10 planned ) machine and used by several designers, worldwide. It was selected especially because it can be run on linux.
the QCAD Professional Site License seems to be the right choice, assuming the maximum of users allowed to run the tool at the same time is limited to the number of licenses available but the amount of designers that can use the tool is bigger. If the licenses are all in use, a designer has to wait for a free one. Is this correct?
how the license has to be maintained? Do you use Flexlm or similar solutions?
worldwide availability is an issue somehow? The tool need be used from different countries.
Thank you!
