I’ve been having a bit of a play with splines, and cannot seem to see any way to join two separate splines together; regardless of whether it’s been created with either with control points or with fit points.
I can split a spline into two with Divide (DI), but can’t see any way to combine two splines by either bridging or merging their end points.
Is there a hidden tool or method I’ve missed, or is this not possible?
Concerting them to polylines isn’t really a solution, as I’d want the two joined end-points to be a single point, and a smooth section of spline just like all the others.
I’m sure the maths are complex, but the long-winded solution I have is to draw a new spline which snaps to the existing points of the two splines I wish to join. Surely it must be possible to select two splines, have the computer remember all the control points that comprise them, and make a new spline with the same points?
Oh well. It’s not for anything urgent or critical. Just seemed to be a gap in the toolset, that’s all.
“Joining” two splines isn’t really a thing as the resulting spline will be different from the two or more original splines.
If you want to create a new spline, reusing the control points (or fit points) of multiple existing splines, you can proceed as follows:
Make sure the drawing order of your splines is the order in which you want to combine the splines
Make sure the splines have the desired direction (start / end point), reverse direction if necessary (Modify > Reverse)
Make sure to check the preference Edit > Application Preferences > Info > Store Positions > Splines > Store Nodes (control points or fit points) for splines
I wasn’t expecting to be able to join the splines and keep the ends of each spline exactly as they were (straight’..? ‘un-spliney’..? can’t think of the correct terminology right now), as once they are joined, they will behave just like all the other control points, with a smooth join, which is what I was wanting.
And your method of storing the control points, and then using those when creating a new spline is exactly what I described.
The resulting new spline will only match if the two merged splines were actually tangent to begin with.
In all other cases it was a discontinuity before and turned in a smooth curvature afterwards.
The change in curvature will not be limited to local either, it might still be noticeable several points away..
Creating two tangent splines sounds easy but that is it not.
There is no start- or end-angle to begin with.
For control point spline one can construct the normal vector at the endpoints.
If one wants to break up a larger spline an merge it back later then the advice is to keep a copy.
Forth and back will not always return the original.
One can also undo the last actions until your back with the original.
