install on centos 8.2 error
[root@iZ2ze6ta7dum4os0vjq46jZ qcad-3.27.6-pro-linux-x86_64]# ./dwg2maptiles
QCAD version 3.27.6
Fatal: This application failed to start because it could not find or load the Qt platform plugin “xcb”
in “”.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, xcb.
Reinstalling the application may fix this problem.
./qcad: line 13: 25441 Aborted (core dumped) QT_AUTO_SCREEN_SCALE_FACTOR=0 LD_LIBRARY_PATH=“$DIR” “$binary” “$@”
QCAD has unexpectedly quit.
Please use the offscreen or minimal platform plugin for headless systems
(without a running X11 server):
./qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
./qcad -style plastique
Please try instead the package:
QCAD Professional 3.27.6 for Linux Qt 5.14 64bit (Installer)
qcad-3.27.6-pro-linux-qt5.14-x86_64.run
[root@iZ2ze6ta7dum4os0vjq46jZ qcad-3.27.6-pro-linux-qt5.14-x86_64]# ./dwg2maptiles
QCAD version 3.27.6
17:07:48: Info: Could not load the Qt platform plugin “xcb” in “” even though it was found.
Fatal: This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: eglfs, linuxfb, minimal, minimalegl, offscreen, vnc, wayland-egl, wayland, wayland-xcomposite-egl, wayland-xcomposite-glx, xcb.
./qcad: line 13: 1681 Aborted (core dumped) QT_AUTO_SCREEN_SCALE_FACTOR=1 LD_LIBRARY_PATH=“$DIR” “$binary” “$@”
Do you have a graphical user interface or just a console? In the latter case, try:
./dwg2maptiles -platform offscreen -h
It seems to work fine on CentOS 8.2 here.
it’s ok,thanks!
