Impossible to install QCAD versions that requires Qt6 on Ubuntu 26.04 [SOLVED]
I want to point out an issue while attempting to install any QCAD version that requires Qt6.
With versions:
3.32.9
3.32.8
3.32.7
I get the following error message:
Warning:  From 6.5.0, xcb-cursor0 or libxcb-cursor0 is needed to load the Qt xcb platform plugin.
20:11:07: Info:    Could not load the Qt platform plugin "xcb" in "" even though it was found.
Fatal:    This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem.
Available platform plugins are: vkkhrdisplay, minimal, linuxfb, wayland-brcm, wayland-egl, wayland, vnc, xcb, eglfs, minimalegl, offscreen.
/home/me/opt/qcad-3.32.9-trial-linux-qt6-x86_64/qcad: line 13: 68846 Aborted                    (core dumped) QT_AUTO_SCREEN_SCALE_FACTOR=1 LD_LIBRARY_PATH="$DIR:$DIR/plugins" "$binary" -platform xcb "$@"
QCAD has unexpectedly quit.
Please use the offscreen or minimal platform plugin for headless systems
(without a running X11 server):
/home/me/opt/qcad-3.32.9-trial-linux-qt6-x86_64/qcad -platform offscreen
In addition, you might have to override the default Qt style
to prevent the loading of a native desktop style (such as GTK):
/home/me/opt/qcad-3.32.9-trial-linux-qt6-x86_64/qcad -style plastique
I checked the dependencies with:
LD_LIBRARY_PATH=. ldd qcad-bin
but got no missing dependencies:
linux-vdso.so.1 (0x00007333c368b000)
libqcadcore.so => ./libqcadcore.so (0x00007333c3000000)
libqcadentity.so => ./libqcadentity.so (0x00007333c34c8000)
libQt6Gui.so.6 => ./libQt6Gui.so.6 (0x00007333c2400000)
libQt6Core.so.6 => ./libQt6Core.so.6 (0x00007333c1c00000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007333c1800000)
libgcc_s.so.1 => /usr/lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007333c2fd2000)
libc.so.6 => /usr/lib/x86_64-linux-gnu/libc.so.6 (0x00007333c1400000)
libQt6Concurrent.so.6 => ./libQt6Concurrent.so.6 (0x00007333c34ad000)
libQt6PrintSupport.so.6 => ./libQt6PrintSupport.so.6 (0x00007333c2f51000)
libQt6Svg.so.6 => ./libQt6Svg.so.6 (0x00007333c2358000)
libQt6Qml.so.6 => ./libQt6Qml.so.6 (0x00007333c0c00000)
libopennurbs.so => ./libopennurbs.so (0x00007333c0200000)
libQt6Widgets.so.6 => ./libQt6Widgets.so.6 (0x00007333bfa00000)
libQt6Network.so.6 => ./libQt6Network.so.6 (0x00007333bf600000)
libm.so.6 => /usr/lib/x86_64-linux-gnu/libm.so.6 (0x00007333c1ada000)
libEGL.so.1 => /usr/lib/x86_64-linux-gnu/libEGL.so.1 (0x00007333c2f3e000)
libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x00007333c17ad000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x00007333c166b000)
libglib-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x00007333c12a8000)
libQt6DBus.so.6 => ./libQt6DBus.so.6 (0x00007333bf925000)
libxkbcommon.so.0 => /usr/lib/x86_64-linux-gnu/libxkbcommon.so.0 (0x00007333c0ba1000)
libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x00007333bf8a0000)
libz.so.1 => /usr/lib/x86_64-linux-gnu/libz.so.1 (0x00007333c2f20000)
libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x00007333bf52b000)
libgthread-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0 (0x00007333c34a2000)
libicui18n.so.73 => ./libicui18n.so.73 (0x00007333bf000000)
libicuuc.so.73 => ./libicuuc.so.73 (0x00007333bec00000)
libicudata.so.73 => ./libicudata.so.73 (0x00007333bcc00000)
libzstd.so.1 => /usr/lib/x86_64-linux-gnu/libzstd.so.1 (0x00007333bf468000)
/lib64/ld-linux-x86-64.so.2 (0x00007333c368d000)
libgssapi_krb5.so.2 => /usr/lib/x86_64-linux-gnu/libgssapi_krb5.so.2 (0x00007333bf848000)
libbrotlidec.so.1 => /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1 (0x00007333c2f11000)
libresolv.so.2 => /usr/lib/x86_64-linux-gnu/libresolv.so.2 (0x00007333c2345000)
libGLdispatch.so.0 => /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x00007333bf3af000)
libexpat.so.1 => /usr/lib/x86_64-linux-gnu/libexpat.so.1 (0x00007333c1aad000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x00007333c1640000)
libatomic.so.1 => /usr/lib/x86_64-linux-gnu/libatomic.so.1 (0x00007333c2f04000)
libpcre2-8.so.0 => /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0 (0x00007333bef54000)
libdbus-1.so.3 => /usr/lib/x86_64-linux-gnu/libdbus-1.so.3 (0x00007333bf35f000)
libGLX.so.0 => /usr/lib/x86_64-linux-gnu/libGLX.so.0 (0x00007333c1275000)
libbz2.so.1.0 => /usr/lib/x86_64-linux-gnu/libbz2.so.1.0 (0x00007333c162b000)
libpng16.so.16 => /usr/lib/x86_64-linux-gnu/libpng16.so.16 (0x00007333c0b67000)
libpthread.so.0 => /usr/lib/x86_64-linux-gnu/libpthread.so.0 (0x00007333c233e000)
libdl.so.2 => /usr/lib/x86_64-linux-gnu/libdl.so.2 (0x00007333c1aa8000)
libkrb5.so.3 => /usr/lib/x86_64-linux-gnu/libkrb5.so.3 (0x00007333bee88000)
libk5crypto.so.3 => /usr/lib/x86_64-linux-gnu/libk5crypto.so.3 (0x00007333c01d4000)
libcom_err.so.2 => /usr/lib/x86_64-linux-gnu/libcom_err.so.2 (0x00007333c1aa2000)
libkrb5support.so.0 => /usr/lib/x86_64-linux-gnu/libkrb5support.so.0 (0x00007333c0b5a000)
libbrotlicommon.so.1 => /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1 (0x00007333bf825000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x00007333c1625000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x00007333c01cc000)
libsystemd.so.0 => /usr/lib/x86_64-linux-gnu/libsystemd.so.0 (0x00007333beaec000)
libkeyutils.so.1 => /usr/lib/x86_64-linux-gnu/libkeyutils.so.1 (0x00007333c01c5000)
Only with version:
3.32.6
that requires Qt5, I had no issue.
Tested with:
Xubuntu 26.04, x86_64
Please run and post the output of:
LD_LIBRARY_PATH=. ldd plugins/platforms/libqxcb.so
You nailed it!
There were some missing dependencies:
linux-vdso.so.1 (0x0000707f010f2000)
libQt6XcbQpa.so.6 => ./libQt6XcbQpa.so.6 (0x0000707f01024000)
libQt6Gui.so.6 => ./libQt6Gui.so.6 (0x0000707f00400000)
libGL.so.1 => /usr/lib/x86_64-linux-gnu/libGL.so.1 (0x0000707f00f8d000)
libQt6Core.so.6 => ./libQt6Core.so.6 (0x0000707effc00000)
libxkbcommon.so.0 => /usr/lib/x86_64-linux-gnu/libxkbcommon.so.0 (0x0000707f00f2e000)
libxkbcommon-x11.so.0 => /usr/lib/x86_64-linux-gnu/libxkbcommon-x11.so.0 (0x0000707f00f22000)
libxcb-cursor.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-cursor.so.0 (0x0000707f00f1b000)
libxcb-icccm.so.4 => not found
libxcb-util.so.1 => /usr/lib/x86_64-linux-gnu/libxcb-util.so.1 (0x0000707f00f13000)
libxcb-image.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-image.so.0 (0x0000707f00f0d000)
libxcb-keysyms.so.1 => not found
libxcb-randr.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-randr.so.0 (0x0000707f003ef000)
libxcb-render-util.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-render-util.so.0 (0x0000707f00f04000)
libxcb-shm.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-shm.so.0 (0x0000707f003ea000)
libxcb-sync.so.1 => /usr/lib/x86_64-linux-gnu/libxcb-sync.so.1 (0x0000707f003e1000)
libxcb-xfixes.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-xfixes.so.0 (0x0000707f003d7000)
libxcb-render.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-render.so.0 (0x0000707f003c6000)
libxcb-shape.so.0 => /usr/lib/x86_64-linux-gnu/libxcb-shape.so.0 (0x0000707f003c1000)
libxcb-xkb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb-xkb.so.1 (0x0000707f003a2000)
libxcb.so.1 => /usr/lib/x86_64-linux-gnu/libxcb.so.1 (0x0000707f00377000)
libX11-xcb.so.1 => /usr/lib/x86_64-linux-gnu/libX11-xcb.so.1 (0x0000707f00372000)
libX11.so.6 => /usr/lib/x86_64-linux-gnu/libX11.so.6 (0x0000707effabe000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x0000707eff800000)
libm.so.6 => /usr/lib/x86_64-linux-gnu/libm.so.6 (0x0000707eff6da000)
libgcc_s.so.1 => /usr/lib/x86_64-linux-gnu/libgcc_s.so.1 (0x0000707f00342000)
libc.so.6 => /usr/lib/x86_64-linux-gnu/libc.so.6 (0x0000707eff400000)
libglib-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libglib-2.0.so.0 (0x0000707eff2a8000)
libgthread-2.0.so.0 => /usr/lib/x86_64-linux-gnu/libgthread-2.0.so.0 (0x0000707f0033b000)
libEGL.so.1 => /usr/lib/x86_64-linux-gnu/libEGL.so.1 (0x0000707effaab000)
libfontconfig.so.1 => /usr/lib/x86_64-linux-gnu/libfontconfig.so.1 (0x0000707eff687000)
libQt6DBus.so.6 => ./libQt6DBus.so.6 (0x0000707eff1cd000)
libz.so.1 => /usr/lib/x86_64-linux-gnu/libz.so.1 (0x0000707eff669000)
libfreetype.so.6 => /usr/lib/x86_64-linux-gnu/libfreetype.so.6 (0x0000707eff0f8000)
libGLdispatch.so.0 => /usr/lib/x86_64-linux-gnu/libGLdispatch.so.0 (0x0000707eff03f000)
libGLX.so.0 => /usr/lib/x86_64-linux-gnu/libGLX.so.0 (0x0000707eff636000)
libicui18n.so.73 => ./libicui18n.so.73 (0x0000707efec00000)
libicuuc.so.73 => ./libicuuc.so.73 (0x0000707efe800000)
libicudata.so.73 => ./libicudata.so.73 (0x0000707efc800000)
libzstd.so.1 => /usr/lib/x86_64-linux-gnu/libzstd.so.1 (0x0000707efef7c000)
/lib64/ld-linux-x86-64.so.2 (0x0000707f010f4000)
libXau.so.6 => /usr/lib/x86_64-linux-gnu/libXau.so.6 (0x0000707eff630000)
libXdmcp.so.6 => /usr/lib/x86_64-linux-gnu/libXdmcp.so.6 (0x0000707eff628000)
libatomic.so.1 => /usr/lib/x86_64-linux-gnu/libatomic.so.1 (0x0000707efef71000)
libpcre2-8.so.0 => /usr/lib/x86_64-linux-gnu/libpcre2-8.so.0 (0x0000707efeb54000)
libexpat.so.1 => /usr/lib/x86_64-linux-gnu/libexpat.so.1 (0x0000707efeb27000)
libdbus-1.so.3 => /usr/lib/x86_64-linux-gnu/libdbus-1.so.3 (0x0000707efead7000)
libbz2.so.1.0 => /usr/lib/x86_64-linux-gnu/libbz2.so.1.0 (0x0000707efef5c000)
libpng16.so.16 => /usr/lib/x86_64-linux-gnu/libpng16.so.16 (0x0000707efea9d000)
libbrotlidec.so.1 => /usr/lib/x86_64-linux-gnu/libbrotlidec.so.1 (0x0000707efea8e000)
libpthread.so.0 => /usr/lib/x86_64-linux-gnu/libpthread.so.0 (0x0000707eff623000)
libdl.so.2 => /usr/lib/x86_64-linux-gnu/libdl.so.2 (0x0000707efef57000)
libsystemd.so.0 => /usr/lib/x86_64-linux-gnu/libsystemd.so.0 (0x0000707efe6ec000)
libbrotlicommon.so.1 => /usr/lib/x86_64-linux-gnu/libbrotlicommon.so.1 (0x0000707efea6b000)
After I installed them, I was able to run the latest version of QCAD.
Perhaps that check should be added to the troubleshooting section.
Thanks.
