I can't change the color of an entity
Hello
I can’t change the color of an entity made with QCAD Simple API
I did some tests (see around line 662 of the attached code) also taking inspiration from Changing entity properties - #2 by andrew
OrthogonalProjections.js (78 KB)
Try:
op.addObject(entity, false);
false: Don’t use current attributes chosen by user.
ok, thanks, it works
