Very dense hatch patterns cause delays. Your file contains several hatch patterns that are too dense to render. QCAD times out after 2000ms by default per hatch entity. You can lower the timeout in the QCAD interface under:
Edit > Application Preferences > Graphics View > Appearance > Display and Performance > Timeout for Hatch Rendering
Or in the QCAD configuration file (~/.config/QCAD/QCAD3.conf):
