Hello how do I convert an arc to a straight line on Quad
Hello! how do I convert an arc to a straight line.
context: My cnc machine has issues with small arcs, it considers the radius too small, but it has no problem with small straight lines. its a whole lot of work to convert small arcs to lines manually, this there a way of converting a selection of arcs into straight lines?
The easiest way I can think of (worth it if you have a lot of these arcs):
  • Select all arcs with a small radius using the selection filter (View > Selection Filter) for example with Arcs, Radius, < (less than), 0.1.
  • Isolate the selection on a separate layer (e.g. Layer > Add layer with Move selection to new layer checked).
  • Convert all arcs to polylines: Draw > Polyline > Polyline from selection, this will deselect your entities as your arcs are replaced by polylines.
  • Select all entities on the new layer again (Layer > Select Layer Entities).
  • Draw > Polyline > Arc to Line Segments.
  • Explode the polylines: Modify > Explode.
  • Optional: move selection back to original layer.
Andrew,
The site https://www.qcad.org/ was not reachable for a longer period today … Except https://qcad.org/doc/
In the light of that event …
I find it curious that this post is almost an exact copy of a former post.
Even QCAD is misspelled in both. “this there a way” is the same typo.
The only difference is the sign off.
See: Hello how do I convert an arc to a straight line on Quad by hannaconner.
ryleybob,
Even small arcs by radius may have a larger sweep angle.
Replacing such with a line segment from start to end may result in a jagged path.
Are you working in inches or in mm?
A typical CNC driver can handle both.
For mm the numbers are 25.4 times larger.
Please specify how small or short that it becomes a problem for your CNC.
Perhaps you could specify the sort, mark and model of your driver and setup.
Are you using QCAD/CAM?
Because that can interpolate arcs on export.
Thanks, CVH. The poster was a spammer indeed. And so was the other poster from July. Both deleted.
