Graphics view background color
My screen has changed to yellow. Looked at drawing prefs and application prefs…
I changed it but cant change it back to white or black.
Also…my lines have disappeared (…thats why I changed the screen to yellow thinking I had somehow changed the line colors…)
You can change the background color under:
Edit > Application Preferences > Graphics View > Colors > Graphics View > Background
Or you can do a complete reset of your installation:
Resetting the QCAD Configuration | QCAD Manual
If you cannot solve your problem with the entities that disappeared, please
  • attach your drawing file (DXF or DWG)
  • let us know what exact system you are on
  • indicate your exact version of QCAD (name of the downloaded installer file if possible (qcad-x.x.x-pro-…)
Thank you so much. Reset to original config did the job.
