Flatpak / hatch issue
Versions
QCAD Professional version: 3.32.9.0
Date: May 6 2026
Qt version: 6.11.0
Compiler version: gcc 11.4.0
Build date: May 6 2026
Revision: 65655b986adef2d302e80e226b64a885fc7601a7
Architecture: x86_64
Device pixel ratio: 2
Configuration file: /home/USERNAME/.var/app/org.qcad.QCAD/config/QCAD/QCAD3.conf
Data directory: /home/USERNAME/.var/app/org.qcad.QCAD/data/QCAD/QCAD Professional
OS: Linux
OS version: 25.08
System:
Kernel: 7.0.0-30-generic arch: x86_64 bits: 64 compiler: gcc v: 13.3.0 clocksource: tsc
Desktop: Cinnamon v: 6.6.9 tk: GTK v: 3.24.41 wm: Muffin v: 6.6.3 vt: 7 dm: LightDM v: 1.30.0
Distro: Linux Mint 22.3 Zena base: Ubuntu 24.04 noble
I proceed like this:
I added hatches to the folder “/home/username/.local/share/QCAD/QCAD/patterns/metric” and restartet QCAD but no hatches appear.
This is what I expect to happen:
The hatches should appear in the context menu.
This is what happens instead:
No new hatches appear.
I found out that I used the flatpak installation of QCAD and the default paths were not correct for that type of installation.
The path “Data directory: /home/USERNAME/.var/app/org.qcad.QCAD/data/QCAD/QCAD Professional” did not exist.
I had to manually create “/home/USERNAME/.var/app/org.qcad.QCAD/data/QCAD/QCAD/patterns/metric”
After that all hatches have been shown as expected.
Is anywhere documented where the default paths are?
You should see the data path QCAD uses under:
Help > About QCAD… > System > Data directory
as posted above.
In there you can add subfolders “scripts”, “patterns”, “linetypes” for your customization. This is all a bit different when using flatpaks.
Okay so you need to manually check if the folders exist based on that info?
These folders can be created by the user if needed. QCAD does not create them automatically at all.
