dxf->writeHatch, but how ?
I havent found how to write a hatch into dxf
We have:
void DL_Dxf::writeHatch1 ( DL_WriterA & dw,
const DL_HatchData & data,
const DL_Attributes & attrib
where DL_HatchData (int hNumLoops, bool hSolid, double hScale, double hAngle, const string &hPattern)
First question: what shoud hPattern be and whats this hNumLoops all about?
Second question:
If I call :
void DL_Dxf::writeHatchLoop1 ( DL_WriterA & dw,
const DL_HatchLoopData & data
should I call the writeHatchEdge functions after this or before the writeHatchLoop?
Third question,why must I call writeHatch2 and how to use it ???
An example would be nice,since its impossible to decode it from the ribbonsofts class reference. Thank you!
The QCAD code has an example:
http://www.google.com/codesearch/p?hl=en#QUfLj_0jKNQ/qcad-2.0.3.3-1.src/qcadlib/src/filters/rs_filterdxf.cpp&q=::writeHatch
Thanks I managed to use it. I inserted a single loop with 3 edges(a triangle :slight_smile: ) and succeded to make a triangle with hatch.
But pattern name is still a mistery.
I tried “EARTH”, “ANSI31”,… default pattern names,but nothing happens. However I can see that names in autocad when I click on my hatchobject, but it doesnt change the hatch style?!
I tried rotate and scale property too,they doesnt work either. Its always a 45 degree hatch.The solid property works fine.
Im having some troubles in writing a solid arc hatch, i wrote a single hatch, with a single loop with a single edge all of em with the same attributes and it just doesnt work, any advice?
Anyone?
wolfhergang: Can you post your code or the exact example data?
I don’t see how a hatch with one loop which contains one arc can form a closed, hatchable contour (unless the arc is in fact a full circle?).
My code is this:
DxfExporter exportador(“testingWriting.dxf”);
exportador.addEntity(new DxfCircle(0,0,0,100,DL_Attributes()));
DL_Attributes generalAttrib = DL_Attributes(“0”,2,16776960, -1, “BYLAYER”);
exportador.addEntity((new DxfHatch(1,true,1,0,“SOLID”,generalAttrib)));
exportador.addEntity(new DxfHatchLoop(1,generalAttrib));
exportador.addEntity(new DxfHatchEdge(0,0,100,0,6.75,true,generalAttrib));
if(exportador.writeToDxfFile()){
std::cout<<“File wrote correctly”<<std::endl;
}else{
std::cout<<“Error at writing”<<std::endl;
in my implementation you “add” the entities to a container then you write the container to the file.
the entity constructors are basically the same as the DL_Entity ones, but mine store the attributes, thats it.
the arc is supposed to be a full circle from 0 to 6.74 degrees but it doesnt render.
pd: sorry about my english, if something doesnt make sense let me know and ill try to explain myself.
Maybe im just confused about how im supposed to hatch things…
wolfhergang: this code does not look familiar to me. dxflib does not provide the classes named “DxfExporter”, “DxfHatch”, “DxfCircle”, etc.
Here’s a minimal but complete example that writes a DXF file with one hatch entity using dxflib 3.3.4:
#include “dl_dxf.h”
int main() {
DL_Dxf dxf;
DL_WriterA* dw = dxf.out(“hatch.dxf”, DL_Codes::AC1015);
// section header:
dxf.writeHeader(*dw);
dw->sectionEnd();
// section tables:
    dw->sectionTables();
    // VPORT:
    dxf.writeVPort(*dw);
    // LTYPE:
    dw->tableLinetypes(1);
    dxf.writeLinetype(*dw, DL_LinetypeData("CONTINUOUS", "Continuous", 0, 0, 0.0));
    dxf.writeLinetype(*dw, DL_LinetypeData("BYLAYER", "", 0, 0, 0.0));
    dxf.writeLinetype(*dw, DL_LinetypeData("BYBLOCK", "", 0, 0, 0.0));
    dw->tableEnd();
    // LAYER:
    dw->tableLayers(1);
    dxf.writeLayer(
        *dw,
        DL_LayerData("0", 0),
        DL_Attributes("", 2, 0, 100, "CONTINUOUS")
    dw->tableEnd();
    // STYLE:
    dw->tableStyle(1);
    DL_StyleData style("Standard", 0, 0.0, 1.0, 0.0, 0, 2.5, "txt", "");
    style.bold = false;
    style.italic = false;
    dxf.writeStyle(*dw, style);
    dw->tableEnd();
    // VIEW:
    dxf.writeView(*dw);
    // UCS:
    dxf.writeUcs(*dw);
    // APPID:
    dw->tableAppid(1);
    dxf.writeAppid(*dw, "ACAD");
    dw->tableEnd();
    // DIMSTYLE:
    dxf.writeDimStyle(*dw, 2.5, 0.625, 0.625, 0.625, 2.5);
    // BLOCK_RECORD:
    dxf.writeBlockRecord(*dw);
    dw->tableEnd();
    dw->sectionEnd();
// BLOCK:
dw->sectionBlocks();
dxf.writeBlock(*dw, DL_BlockData("*Model_Space", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "*Model_Space");
dxf.writeBlock(*dw, DL_BlockData("*Paper_Space", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "*Paper_Space");
dxf.writeBlock(*dw, DL_BlockData("*Paper_Space0", 0, 0.0, 0.0, 0.0));
dxf.writeEndBlock(*dw, "*Paper_Space0");
dw->sectionEnd();
// ENTITIES:
dw->sectionEntities();
DL_Attributes attributes("0", 2, 0, -1, "BYLAYER");
// start hatch with one loop:
DL_HatchData data(1, false, 100.0, 0.0, "ESCHER", 0.0, 0.0);
dxf.writeHatch1(*dw, data, attributes);
// start loop:
DL_HatchLoopData lData(1);
dxf.writeHatchLoop1(*dw, lData);
// write edge:
DL_HatchEdgeData eData(
    0.0,
    0.0,
    100.0,
    0.0,
    M_PI*2,
    true
dxf.writeHatchEdge(*dw, eData);
// end loop:
dxf.writeHatchLoop2(*dw, lData);
// end hatch:
dxf.writeHatch2(*dw, data, attributes);
// end section ENTITIES:
dw->sectionEnd();
dxf.writeObjects(*dw, "MY_OBJECTS");
dxf.writeObjectsEnd(*dw);
dw->dxfEOF();
dw->close();
delete dw;
return 0;
My problem was that i was writing the hatch edge using degrees when im supposed to use radians.
DL_HatchEdgeData eData(0.0, 0.0, 100.0, 0.0, M_PI*2, true);
that single line solved my problem, than you very much Andrew.
