I have an issue when using command line tool dwg2pdf.
When I print one layout/block, the -auto-orientation and -page switches seem to work fine.
When I change the command by using regexp in the block, so that I can print multiple pages into one PDF, then the orientation is always portrait and page settings is reset to A4.
What am I doing wrong, please?
C:\Program Files\QCAD>dwg2pdf.bat -o "C:\Users\mjansa\Dropbox\Kadlín\Plány\Moje výkresy\Single-page.pdf" -f -auto-orientation -auto-fit -color-correction -p="ISO A3 (297x420)" -block="Stávající_Energie" "C:\Users\mjansa\Dropbox\Kadlín\Plány\Moje výkresy\Tepelná obálka.dxf"
QCAD version 3.32.4
13:30:16: Debug: loading plugins...
13:30:16: Debug: RHelpPlugin::init
13:30:16: Debug: RPolygonPlugin::init
13:30:16: Debug: RProScriptsPlugin::init
13:30:16: Debug: RProxiesPlugin::init
13:30:16: Debug: RTracePlugin::init
13:30:16: Debug: RDwgPlugin::init
13:30:16: Debug: loading static plugins...
13:30:17: Debug: var: "WorkingSet/AttributeIds"
13:30:17: Debug: val: QVariant(QString, "")
Warning: old and new property values for property "Arrow block" have different types: QString vs. int
Converting
from: C:\Users\mjansa\Dropbox\KadlĂn\Plány\Moje vĂ˝kresy\Tepelná obálka.dxf
to : C:\Users\mjansa\Dropbox\KadlĂn\Plány\Moje vĂ˝kresy\Single-page.pdf
13:30:23: Debug: exporting layout: St?vaj?c?_Energie (*Paper_Space4) [5]
Warning: RGraphicsViewImage::paintOverlay: no workers
C:\Program Files\QCAD>dwg2pdf.bat -o "C:\Users\mjansa\Dropbox\Kadlín\Plány\Moje výkresy\Multi-page.pdf" -f -auto-orientation -auto-fit -color-correction -p="ISO A3 (297x420)" -block="Stávající_.*" "C:\Users\mjansa\Dropbox\Kadlín\Plány\Moje výkresy\Tepelná obálka.dxf"
QCAD version 3.32.4
13:29:42: Debug: loading plugins...
13:29:42: Debug: RHelpPlugin::init
13:29:42: Debug: RPolygonPlugin::init
13:29:42: Debug: RProScriptsPlugin::init
13:29:42: Debug: RProxiesPlugin::init
13:29:42: Debug: RTracePlugin::init
13:29:42: Debug: RDwgPlugin::init
13:29:42: Debug: loading static plugins...
13:29:43: Debug: var: "WorkingSet/AttributeIds"
13:29:43: Debug: val: QVariant(QString, "")
Converting
to : C:\Users\mjansa\Dropbox\KadlĂn\Plány\Moje vĂ˝kresy\Multi-page.pdf
13:29:54: Debug: exporting layout: St?vaj?c?_Energie (*Paper_Space4) [5]
13:29:54: Debug: exporting layout: St?vaj?c?_?ezy (*Paper_Space5) [6]
13:29:56: Debug: exporting layout: St?vaj?c?_P?dorysy (*Paper_Space6) [7]
13:29:58: Debug: exporting layout: St?vaj?c?_Zateplen? (*Paper_Space) [8]
Thank you,
Marek
Windows 11 24H2 64-bit
QCAD Pro 3.32.4.0 (3.32.4)
Multi-page.pdf (1.4 MB)
Single-page.pdf (179 KB)
