I’ve just begun using this library. Starting with your example, I can draw straight lines and points.
However, with a given set of points, what function do I have to use if I want to connect them ?
I thought about using spline or polyline but I can’t get it work.
hello am trying to use the dxflib to extract the lwolyline form a dxf file.
so i can extrude it later on.
I saved the vertices of the polyline in an array
but i cant draw the polyline am not sure what would my problem be.
am new to dxflib
my code looks exactly as the one u mentioned here .
and i used a while loop to get all the vertices from my array
is there any paper where i can read more about the dxf polyline !
anyhelp would be appreciated
thank you
nour
Of course you have to call Polyline in the entity section. The reason it doesnt work might be that you use incorrect parameters in DL_PolylineData.
I will add my code.
Im using my own wrapper class. I defined the entities(line,polyline,hatch,circle,etc) each as a class, and for each class type there is a vector, that holds the entities I draw.
For instance the class polyline has variables like layer name,color,line width and of course the coordinates for each vertex.
Here is my code for the polyline caddrawing:
for (int i=0;i<polylines.size();i++){ // for each polyline
for (int j=0;j<polylines.NumOfVertex;j++){ //for each vertex in poly
dxf->writeVertex(*dw,DL_VertexData(
polylines.Polyline.GetX(j),
polylines.Polyline.GetY(j),
polylines.Polyline.GetZ(j),0));
} //end for each vertex
dxf->writePolylineEnd(*dw);
}//end for each polyline
So: polylines is the vector of my polyline class.
You have to know how many verteces each polyline consist of.
I store this number in polylines[i].NumOfVertex
In DL_PolylineData( polylines[i].NumOfVertex, … ) you have to define how many verteces you are using and you must call
dxf->writeVertex(…) exactly the same time, otherwise it wont display anything.
i’ll check my code again I found that it writes something but its not giving me the results i wanted.
am using dxf files that i created using visio.
but when import them to maya nothing appears may b also I have a problem in my original dxf files !
do you know if its possible to apply extrusion on this polyline ?!
i mean converting the lwpolyline to 3D polyline?
yes its has the z coordinate ! and i can draw the extracted polyline
may b with some wrong coordinates but i can work on that and i tested writePoint and writeline both works fine
but i was thinking of extracting this polyline and extruding it.
as its polyline and has no width or thickness am not sure how to do that am using maya and never worked with 3D ! its a bit confusing
