Does not print
I have tested on two computers, one with windows 10 and the other with windows 11.
On W10 it prints nothing and on W11 it prints only part of the dimension layer. All the layers are activated except the unprintable DefPoints layer.
The printer is a LasetJet M15.
I have tried with color, and black and white and the result is the same.
If from the same print action I export it to PDF it saves it without problem and I can print it from Acrobat, so the printer is ok.
I don’t know what could be happening.
If you can help me, thank you.
Please refer to our printing tutorial at:
Including the Troubleshooting section about thin or invisible lines.
If you cannot solve the problem, please attach your drawing so we can help efficiently. Please consider also the forum rules at the top of this page in red, thanks.
The real question here is:
Why is an export to PDF not the same as the page printed directly?
What is handled different and why?
IMHO, a PDF should be a digital paper copy without cutting down trees. :wink:
