Diametric dimension outside the circle
As you can see in the image below, sometimes there is no space inside a circle for the dimension.
So let’s move it outside. That can be done by exploding the dimension. That works fine. BUT: Later, when you change the dimension settings in your drawing preferences, this exploded dimension will not be changed with the rest of the dimensions.
So it would be really great if we could just drag the number to the outside of the circle (example in the middle) AND the dimension line would be extended automatically (example on the right).
In my right example, the number is moved outside and the green line is just added manually as an extra entity. In this way, when changing the dimension settings, the number and arrows are still scaled up/down.
Feature request added at:
Ping. Agreed. For circles inside larger drawings it leave the dim in a messy place. Radius works this way but easier for the machinist to use the Diam rather than math it.
A work around of sorts is to set the arrows to be on the outside of the circle. Grab the text and move it. Then draw a line from the text to the appropriate arrow. You end up with 2 arrows but it gets the text out of the middle of you internals and looks decent.
