Please check for missing dependencies:
cd ~/opt/qcad-3.32.9-pro-linux-qt6-x86_64
LD_LIBRARY_PATH=. ldd qcad-bin `find . -name "*.so"` | grep "not found"
You need to install the packages providing the missing libraries listed.
From your output, I can already see that at least these are missing:
xcb-cursor0
libxcb-cursor0
You can fix these with:
sudo apt install libxcb-cursor0
Pro-Tip: Let Ubuntu Find It Automatically
If you ever run into a similar issue where a program complains about a missing libsomething.so file, you can use a tool called apt-file to search for the exact package name.
Install the tool:
sudo apt install apt-file
Update its database:
sudo apt-file update
Search for the missing file:
apt-file search libxcb-cursor.so
This will tell you exactly which package you need to install.
flatpak
If you are ready to leave the dependency mess behind you, you may want to install a flatpak instead:
QCAD - QCAD Installation on Linux from Flatpak
Good morning andrew,
Thank you very much for your help, that fix the issue and qcad works now.
However, I did not notice an improvement in speed or reaction on big files.
Every action pops up the wait / quit dialog and it takes long time to react even to zoom or displace the drawing. It is usable for small areas and hope in the future this can improve.
Thanks again for your effort.
carlos
I can confirm that neither QCAD 3.32.9 nor Qt 6 address any kind of performance issues. Your files might simply be too complex for QCAD to handle. A common issue are also very dense hatch patterns or very dense line type patterns. Your file would help us to identify the problem.
