Corkscrew or streching an ellipse
Is there a built-in way of stretching an ellipse with one cut point into a “corkscrew” ? The stretch function doesn’t seem to be able to do that.
The arrow is perpendicular to the ellipse’s plane
I don’t see how this would be mathematically defined.
Perhaps a spline is better suited for what you are trying to do?
a spline is what I ended up doing but I was wondering if there was an easier way.
Essentially, it’s an helix in an isometric view. I’m sure there’s a mathematical representation of that, but it’s been too long since I’ve done that kind of math.
I have faced that problem when drawing schematic symbols of coils and transformers. The 3D view of a helix is exactly what is generally used for the coil in these drawings. It is easy for a rough helix to be drawn by hand, which is probably why they are used - grandfathered in from the old days, so to speak. But I have used about a half dozen 2D CAD programs and none of them, in my memory, could do this accurately.
My work-around is to use two arcs, about 90 degrees each and connecting them at one end, sort of football shaped. The other ends are stopped somewhat short of actually meeting and the next “coil” is attached with those points so each coil (pair of arcs) is offset from the previous. This was good enough to get the idea across.
I guess you could replace the points of joining with more arcs with smaller radii (chamfers) if you need a better approximation. This would be sort of like the old manual drafting method of approximating an ellipse with four arcs. It ain’t perfect, but it can look nice. Of course more arcs adds more size to the part so it’s a compromise.
Another way, which would probably be a lot of work, would be to create the helix in a 3D CAD program and take a screen shot. Then import that screen shot into QCAD and either just use it or draw over it with splines or whatever.
My attached photo shows a helix simulated with an ellipse and an arc. The red is an ellipse with a segment removed. That elliptical segment is repeated up and down. And the green is an arc that was sized to fit between two adjacent copies. It is also repeated. It is a fairly good approximation.
Already looking far better. :stuck_out_tongue:
Although it is not a Helix or Corkscrew in perspective …
The approximation by an ellipse is fairly logical because a winding is about a circle an in perspective that is an ellipse.
The rather short arc is a nice replacement for yet another part of an ellipse.
Together it will yield a good approximation at low rendering calculation costs.
Nice :exclamation:
Now I wonder on how good the approximation is.
Would you want to consider to share your design within a drawing file?
I expect that the curvature should differ for the far and the near part while that is symmetric in your case.
I am attaching the file for that helix part.
I had a bit of a problem making it and a compromise was necessary. That was good enough for my purpose which was a nice looking schematic symbol. Accuracy was not really necessary. As you know I am a QCAD newbee so perhaps you know of a way to do that I could not find.
Drawing and removing a part of the ellipse was trivial. I simply drew a vertical line and used the Break Out Segment command in the Modify menu. But I could not find a way to precisely draw an arc between the end of one ellipse and the opposite end of the next, making it tangent to both. Ideally I wanted to specify the middle point of the arc, but that would have been greedy. I tried the Tangent restraint but could not get it to work. So I just zoomed in tight and drew the arc by sight. Then the Trim Both command, also in the Modify menu to have the arc and ellipse meet at a point. It came out great looking, but is not precise even for the use of an arc for the approximation to the helix.
If by “far and the near part” you mean the top and bottom ends of the helix in my drawing, then the partial ellipse and the arc are exactly the same at both ends. I did not make any effort at true perspective. It is only a nice looking symbol.
And YES, I was trying to avoid elements, like a spline, that would require excessive rendering time. This helix will be used in a number of schematic symbols and more than one may be on a given drawing.
CoilWithCTVert800.dxf (102 KB)
Indeed kinda problematic and remark that the lower part of your little arcs ‘overlaps’ with the ‘next’ ellipse arc.
  • There is a lack of tangent arc drawing methods but that is usually solvable with full circles and trimming.
  • Tangent to ellipses is only provided for a few line tools.
The solution is drawing a normal or tangent at the intended (end-)point on (of) the ellipse (arc).
  1. Let us first agree that in this symmetric setup all endpoints of the ellipse arcs are trimmed to a vertical line.
    … Depending the situation that may fail with ellipse arcs using Trim (RM) because it only works in one direction.
    … Auto trim (AX) may be a solution when there is nothing else to trim to …
    … Otherwise alter the Start or End angle so that it is too long and Break away (D2) the excess.
  2. For clarity I have included point entities of interest in Mode 32, see Drawing Preferences .. General .. Points Display.
    3a) Draw 2 auxiliary lines from an endpoint to the foci of the ellipse.
    … The foci are reference points and displayed when you select an ellipse (arc).
    … Harder to select at the open side but these are symmetric and one can mirror the other over with regards to the ellipse orientation.
    3b) Construct the angle bisector of these 2 auxiliary lines.
  3. The normal or tangent is orthogonal to the angle bisector in the intended (end-)point.
    5a) Construct a circle from a tangent and two points (CT1)
    … Indicate the normal (Cyan) and the two endpoints (green).
    5b) Remove all auxiliary constructions and trim the circle with Break out Segment (D2) removing (see Option Toolbar) the obsolete part.
Steps are visualized in the attached file each on a separate layer, just make them visible one by one for stepping trough.
I added ‘Far’ and ‘Near’ on an extra layer. :wink:
HowTo_ArcTangent2ptOfEllipses.dxf (102 KB)
When non-symmetric one needs to construct both normals in both endpoints and use CT2 :wink: .
I neglected to mention that I was also trying to give the finished “helix” a given width. So the mid point of my arc would need to be at that width from the opposite side of the “helix”. I drew the “helix” as part of my collection of electronic symbols and wanted to keep things on a grid. But in the end, after scaling for the vertical distance, it would up off-grid anyway.
Of course I knew that perpendiculars to the ellipse ends would result in a center for the arc for the tangent condition. But then the mid point of the arc would fall where it may. Now that I look back, I could have constructed the arc as you describe and then use the scale function to bring the width of the resulting “helix” to the value I wanted. In fact, being the perfectionist that I am, I will probably go back and do it that way.
I finally got back to creating my electronic symbols and the coil (a helix) in particular. I was trying to get one that looked better and it seemed to me that the arc that I used previously would look better if it were stretched out. In other words, an elliptical segment. But that would making two elliptical segments meet tangentially. Here’s how I did it:
I used two half ellipses. That way they would meet along their center lines where both of them would be horizontal. That would easily guarantee they were tangent. The green ellipse was drawn 1" wide by 0.3" tall. That was by experiment. Then it was copied down by 0.2". The red ellipse was drawn with the same center line but half way between two green ones. It was drawn 0.3" x 0.1". Those two meet tangentially at the center line. I used the Break Out Segment command to remove the unwanted parts of each. I added two center cross/circles to show their respective centers. And then they were copied down at 0.2" increments.
This produced a very visually pleasing pseudo-helix. And the trick of having them meet on their center lines took all the difficulty out of keeping them tangent.
My next step will be to add horizontal lines for the connections and use X-Y scaling to bring the overall size in agreement with my other symbols while keeping the connections on a 0.1" grid for easy drawing of the connecting wires.
Again looking better, more natural … Nice :stuck_out_tongue:
Far/near comes out better too this way.
Using a second ellipse arc is again logical and of course always neater but it increases the rendering efforts.
My desktop computer is around 10 years old and wasn’t anything great when I bought it. It does not seem to struggle with one or two of these “helices” in a drawing. But that proves nothing.
It would seem that there are three choices for this: circular arcs, elliptical arcs, and splines. And all of them must be drawn with straight line segments, each of which takes time to generate and display. I assume that a circular arc, when stretched, becomes an elliptical arc.
Any thoughts on which would render faster? And would different processors change the relative ranking?
Just wondering.
No, 1 or 2 proves nothing. :wink:
I presume in the order of complexity:
Lines - Arcs - Ellipses and then Splines with increasing degree 1,2,3, … with increasing number of points.
Although that splines in degree 1 are nothing but straight segments but they are based on polynomials. :wink:
It will also matter how large the curved shape is and thus with how many tiny straight segments it is rendered.
Ellipses should require more effort because one can only solve them with elliptic integrals or infinite series expansion until converging.
Rather much more complex than simply stretching. e_geek
But series expansion is only partially implemented by me in 2D Centroids to be utterly correct for the ellipse (arc) length.
In general QCAD exploits less demanding and approximated methods.
Qua CPU I think that only the clock-rate really matters, it is probably not a numbers of cores issues.
Modern CPU chips are all equipped with some sort of FPU core.
I am unaware how blocks are rendered, as each Block Reference apart or as Block and then translated, scaled and painted.
One could test that with adding 100, 1000 or more Block References.
Of A) a Block with N arcs or B) a Block with N ellipse arcs, both of about the same size.
Lagging will increase considerable when each Block Reference is treated apart increasing the number of …
… And there may be a very noticeable difference between a file with case A compared with one with case B.
You’re probably happy with your current solution, as it is elegant and visually pleasing, but for anyone who’s interested, here’s how I, as a draftsman, would draw an accurate helix in 3D.
This construction can be adapted for any axonometric or oblique drawings.
With pencil and paper, I’d draw an ellipse, and find the 12 equal divisions using a 30/60 set square. My ellipse has major and minor axes of 200 and 40, respectively.
However, I discovered that for a smooth helix shape, QCAD’s spline needs more than 12 points to give an acceptable curve. I can draw one better by hand because I know what a helix looks like. So instead of the above, I made my ellipse out of a 24-sided polygon. It means a tiny bit extra work, but really not much. Same size as above.
Decide what the ‘lead’ of the helix is. This is the amount the helix moves forward (in this case, up) with each rotation. Because we have 24 divisions, at each step round the polygon, we add a point that gets incrementally higher. (I’m adding vertical lines with a point marking the end for clarity.)
So my lead is going to be 60, meaning that each of the 24 steps around the polygon, the point rises up by 60/24, or 2.5.
I add points at 0 (on the first, at ‘ground level’) then 2.5, 5, 7.5, 10, 12.5, 15, 17.5, etc etc until I reach the point I started at, where I add a second point from the starting position at 60, which will be the beginning of the next rotation.
You can probably see where this is going now. Draw a spline passing through these points.
Now, copy and paste as many rotations of the helix you want. These are separate curves, and the end points won’t be a perfectly smooth join. If you want them all linked, just select your curves in order, and go to Misc: Information: Store Positions.
Now activate the Spline (SL) tool, and Go to Misc: Information: Use Positions.
A single spline using the same points as your separate ones will be created.
By varying the proportions of your ellipse and the lead, you can achieve different results using the same method.
Derek
And here’s a dxf file with an accurate helix attached, using the same proportions and lead as the last image that Chips&Chips posted…
Cheers,
Derek
Helix-16x4Ellipse-Lead4.dxf (135 KB)
Nice, thank you …
Probably the best solution up to now. :sunglasses:
You have to admit that what Chips&Chips presented on Feb 29 comes very close visually.
I don’t think that it must be exact for the intended purpose … :wink:
One of the problems I see is that in QCAD splines end normal.
Your start and end curvature is thus not entirely correct between the last 2-3 fitpoints at either side.
Solution:
Overdo it at least 2 extra points at both ends and trim the fit-point spline at the Y axis.
That will result in a control point spline with proper end tangents.
An unanswered question is rendering load.
How much more lag do 8 splines of degree 3 induce compared to 16 ellipses and that for numerous helix blocks inserted on drawing?
And how does that compares with your final spline with 193 fit-points (8x24+1)?
Selecting a 10 by 10 array of such blocks takes about 2-3 seconds on my old Pentium 7.
Some quick test tells me that the spline block is faster … :stuck_out_tongue:
Last question:
What type of projection is this?
Your X axis is horizontal and both your Y and Z axis are vertical … :confused:
  • Cheers. you’re welcome. I’m sure some clever person could write a script to do the same thing, but that’s how a 3D view of a helix should be constructed— with pencil and paper at least. And it’s easy enough to use in cases where a “Draw helix in 3D” button doesn’t exist. : :smiley:
  • Yeah, totally agree. His solution was nice visually, and looked good for a diagramatical representation. Certainly a nicer result than the traditional simplified version of a helix…
    edit: Worth noting that the original poster, sancyk, was asking about a helix in isometric, so I hope this has been helpful for them, even though Chips&Chips may not have needed an accurate solution.
    And these aren’t even in 3D. LOL
-Yeah. If I was doing something where I wanted the end tangents correct, I’d add an extra revolution on each end, and then cut them off where I needed.
  • Well, I’m not running QCAD on a Pentium 7, so you’re in a better position to judge that. :wink: But looking at the traditional ‘simplified’ helix, this method could even be massively simplified to a dozen, or even fewer straight lines per rotation. Depends how detailed a diagram or representation needs to be, and how prominently the helix will feature.
    Here’s one with 8 lines per rotation (not even a spline), which would be acceptable in certain circumstances, and another with only 4 lines per rotation, which is about as bare-bones as you can get. It’ll render really, really fast, but I don’t think even I’d use it except under duress. :slight_smile:
    I only really threw these together to illustrate that the construction can be as detailed or as simple as required.
  • That last one in my original post was a dimetric projection. (I’d have normally done an example in isometric, but I wanted to try and match the spacing in Chips&Chips’ drawing, so ‘reverse engineered’ the minor axis of the ellipse to match)
    In both dimetric and isometric, once the view is rotated 45 degrees and then foreshortened, it is still a perfect ellipse, (as there is no perspective distortion) so it doesn’t matter that it was drawn in such a way that it appeared that the x, y and z axes were horizontal and vertical. In Chips&Chips’ drawing, he had the starting point of the helix ‘front and centre’, so I did my drawing to match that.
    Here’s the standard construction (with an unneccessary bounding square added for clarity), and it converted into isometric.
    As you can see, there isn’t a 30/60 line intersecting the ellipse at a point where I wanted it, at the lowest point of the circle.
So if I rotate the circle and lines by 45 degrees first, and then convert/foreshorten it for isometric, The ellipse is identical, but this time I have my construction lines exactly where I want.
edit: Worth noting too, that as I ended up using a circle divided into 24 parts, not the 12 I would use if drawing one by hand, there’s no need to rotate it 45 degrees at all.
Planometric drawings are easy, because the ‘top’ view is a perfect circle anyway.
For auxiliary projections, trimetric, cavalier or cabinet, (and I were doing it by hand) I’d probably use the enclosed parallellogram method to locate my key points for my base circle that I project the helix up from:
But of course, QCAD has some great built in functions to convert orthographics into those types of drawings.
Cheers,
Derek
