Confused with version numbers
QCAD Version: 3.32.4.0
Operating System: Ubuntu 22.04.5 LTS?
Provide details, exact error messages, warnings, etc.
I am confused by the version shown in ABOUT (3.32.4.0) and thee new version I am told is available (27.0.5). When I download the .run file and install on my intel x86 64bit machine the ABOUT show the same old version number (3.32.4.0)
What should I see? Am I doing something run with the install?
David
As we switched to calendar versioning, you should indeed see 27.0.5 after installing that version. If you still see the old version, this means that you are still using the old version. Please refer to our web site for installation instructions:
Thank you for reply.
I tried installing an older version (27.0.4) as I received an errror message indicating the glibc version was too old, however I received the same error message
"QCAD could not be started.
The system libraries of this Linux distribution are too old for this version of QCAD.
Required but not available: CXXABI_1.3.15 GLIBC_2.38 GLIBCXX_3.4.32
Installed: ldd (Ubuntu GLIBC 2.35-0ubuntu3.18) 2.35
Please upgrade your Linux distribution or use an older version of QCAD."
As a non power user of linux I failed in my attempts to upgrade glibc and would appreciate some help in installing the relevant glibc package or the most up to date version compatible with my 2.35 version of libc.
Regards David.
Thanks for the details.
Your installation went fine. The problem is that QCAD 27 for Linux needs a newer system library (glibc 2.38) than Ubuntu 22.04 provides (2.35).
QCAD 27.0.4 has the same requirement as 27.0.5, so going back a release won’t help. QCAD 27 never started on your system, so you were still running your old 3.32.4 installation.
Please don’t try to upgrade glibc by hand. It’s a core system library, and replacing it can leave Ubuntu unable to boot.
You have two good options:
  1. Upgrade to Ubuntu 24.04 LTS (recommended). Open Software Updater, or run sudo do-release-upgrade in a terminal. Back up your files first. Once you’re on Ubuntu 24.04, QCAD 27 installs and runs normally.
  2. Stay on Ubuntu 22.04 and keep using QCAD [3.x.y], which works with glibc 2.35.
Thanks for the options…I totally agree and have already upgraded to 24.04, albeit reluctantly as I have a few bad experiences of upgrades causing me to clean install and everything that entails. This time the upgrade went well and the QCad 27.0.4 installed fine and ran without hiccups.
Many thanks for your excellent help and advice.
Looking forward to renewing licence soon.
Regards, David
