After a PC crash, I am trying to re-install ver 3.15.5-pro-linux_x86_64.tar.gz on a updated Ubuntu OS - ver 24.04.1 LTS (64 bit) without success.
I have followed the Linux install instructions for this file set - extracted the files to a directory and ensured the Qcad binary file is set to Executable.
In Terminal:
Set the directory correctly
Typed ./qcad and got the following message:
./qcad-bin: symbol lookup error: /lib/x86_64-linux-gnu/libfontconfig.so.1: undefined symbol: FT_Done_MM_Var
Then following the error investigation:
LD_LIBRARY_PATH=. ldd qcad-bin reported no apparent errors viz:
linux-vdso.so.1 (0x00007ffc0bffd000)
libqcadecmaapi.so => ./libqcadecmaapi.so (0x00007456b4800000)
libqcadgui.so => ./libqcadgui.so (0x00007456b476b000)
libqcadentity.so => ./libqcadentity.so (0x00007456b4649000)
libqcadoperations.so => ./libqcadoperations.so (0x00007456b5b19000)
libqcadspatialindex.so => ./libqcadspatialindex.so (0x00007456b5b09000)
libspatialindexnavel.so => ./libspatialindexnavel.so (0x00007456b4000000)
libqcadgrid.so => ./libqcadgrid.so (0x00007456b5afa000)
libqcadsnap.so => ./libqcadsnap.so (0x00007456b5ae5000)
libqcadcore.so => ./libqcadcore.so (0x00007456b3a00000)
libqcadstemmer.so => ./libqcadstemmer.so (0x00007456b4619000)
libqcadzip.so => ./libqcadzip.so (0x00007456b5ae0000)
libquazip.so => ./libquazip.so (0x00007456b3400000)
libQtWebKit.so.4 => ./libQtWebKit.so.4 (0x00007456b1800000)
libQtScriptTools.so.4 => ./libQtScriptTools.so.4 (0x00007456b1200000)
libQtScript.so.4 => ./libQtScript.so.4 (0x00007456b0a00000)
libQtSvg.so.4 => ./libQtSvg.so.4 (0x00007456b0400000)
libQtXmlPatterns.so.4 => ./libQtXmlPatterns.so.4 (0x00007456afa00000)
libQtOpenGL.so.4 => ./libQtOpenGL.so.4 (0x00007456af400000)
libQtXml.so.4 => ./libQtXml.so.4 (0x00007456aee00000)
libGL.so.1 => /lib/x86_64-linux-gnu/libGL.so.1 (0x00007456b4592000)
libQtDesigner.so.4 => ./libQtDesigner.so.4 (0x00007456ae400000)
libQtHelp.so.4 => ./libQtHelp.so.4 (0x00007456ade00000)
libQtSql.so.4 => ./libQtSql.so.4 (0x00007456ad800000)
libQtGui.so.4 => ./libQtGui.so.4 (0x00007456ac800000)
Thanking you for your assistance in advance.
Martin
