Hello, I am using Qcad community edition: have tried on big linux, manjaro, and Zorin. Each instance will not show my printer. If I click file, print, it gives and option for PDF save, but shows no printers connected for an option. Other apps on these systems print fine. Any ideas how to proceed would be very helpful. Thanks in advance
A previous similar question - QCAD Does Not See Printer - was fixed by using this terminal command…
sudo ln -s /var/run/cups/printcap /etc/printcap
Hello, and thanks for the response
Tried that command I had found earlier, and tried it again today on several distributions. Still no luck with Qcad seeing a printer.
Have still been playing around with trying to recognize my printer. Here is what I get when I run the suggested command:
[sudo] password for kevinp:
ln: failed to create symbolic link '/etc/printcap': File exists
Anyone have this issue or solutions?
This means that there is already a file at
/etc/printcap
Please have a look at that file with a text editor or with:
cat /etc/printcap
It might just be a dummy file, present for software that need that file to exist or it might have meaningful content. If it’s just empty or has dummy content, you may want to replace it with your /var/run/cups/printcap or delete it and link your /var/run/cups/printcap to /etc/printcap.
Sorry, I hit solved by accident
However, here is what I have run, still not able to print in qcad. Doesn’t recognize printer
❯ sudo ln -s **/var/run/cups/**printcap /etc/printcap
ln: failed to create symbolic link ‘/etc/printcap’: File exists
kevinp ~ 12:24:25
❯ cat /etc/printcap
[bat error]: ‘/etc/printcap’: No such file or directory (os error 2)
kevinp ~ 12:24:54
kevinp ~ 12:24:25
❯ cat /etc/printcap
