Hi all,
I am not so good with wayland, qt or c/c++ but I want to build qcad and run it on my Raspberry Pi 5, preferably with the qt libraries that comes with RaspiOS.
I’m well aware that this is not a supported environment (I use Windows for that even if I have to renew my license) but for me it would be great to be able and do some work on the RPi from time to time.
I have gotten as far as qcad compiling without errors but when I try to run it fails to find a shell integration. It tries to start but hangs and I have to end it with ^c.
$ LD_LIBRARY_PATH=. ./qcad-bin
QCAD version 3.29.3.2
12:21:14: Debug: loading plugins...
12:21:14: Debug: loading static plugins...
Warning: Failed to load client buffer integration: "wayland-egl"
Warning: Available client buffer integrations: ()
Warning: No shell integration named "xdg-shell" found
Warning: No shell integration named "xdg-shell-v6" found
Warning: No shell integration named "wl-shell" found
Warning: No shell integration named "ivi-shell" found
Warning: Loading shell integration failed.
Warning: Attempted to load the following shells ("xdg-shell", "xdg-shell-v6", "wl-shell", "ivi-shell")
Can anyone here give a hint on whats going on. I can see that it tries to load the “waylang-egl” integration but fails and then fails with a bunch of other but is there a wayland integration that possibly would work for raspberry and if so how do I get it compiled and detected correctly?
Thanks in advance.
[edit] and yes it works in X11 but that’s not a solution
