QCAD Version: 27.0.0
Operating System: Mxlinux
Hi Andrew,
I would like to report a severe crash I encountered in QCAD 27.0.0 Pro on Linux (Qt6 x86_64, MX Linux) related to Viewport management and Layout blocks.
Steps to reproduce:
- Go to Edit > Drawing Preferences > Layout > Viewports.
- Change the view configuration to Two:Vertical and click OK.
- Open the Block list panel.
- Double-click (left mouse button) on Layout1 to switch to it/edit it.
Result:
The application crashes instantly.
Additional notes on behavior:
- This crash happens specifically if the Viewport configuration was changed before attempting to open/edit the Layout block.
- If
Use RHI Graphicsviewis turned ON, changing the viewport layout to Two:Vertical also causes immediate UI artifacts and a crash. - If
Use RHI Graphicsviewis turned OFF, the viewport change itself works, but the crash triggers later — exactly at the moment you double-click Layout1 in the Block list.
