Black and white PDF export produces grayscale output with RHI enabled
QCAD Version: 27.0.4
Downloaded package (file name): qcad-27.0.4-pro-linux-qt6-x86_64.run
Operating System: Linux Mint
I’ve noticed an issue with PDF export in QCAD Pro 27.0.3 on Linux.
When exporting a layout block to PDF with Black & White selected, the resulting PDF is actually in grayscale. This makes some lines, especially those on yellow layers, very faint and almost invisible.
The layout looks fine in QCAD, but the problem occurs both when using Export PDF and when printing to PDF.
I’ve done a few tests:
  • RHI enabled: PDF comes out in grayscale instead of black and white.
  • RHI disabled: everything works correctly.
  • dwg2pdf: also works correctly, even with RHI enabled.
So it seems to be an issue with the RHI rendering engine. Is this a known bug? I’d rather not have to disable RHI every time I need to export a drawing.
Thanks!
Thank you for your report.
Bug report at:
Fixed in 27.0.5, available now.
