Any issues after upgrade to MacOs Ventura?
Hi guys,
Iam wondering. Are there any issues after the upgrade to MacOs Ventura? Is Qcad still working smoothly, or are there any problems? Can you let me know before I upgrade? Thank you.
Regards
Radek
After playing around for just a short time with QCAD 3.27.8 on Ventura, I’ve had no issues. If that changes I’ll let you know.
Thanks for your reply. I think I can upgrade also.
It is crashing when opening dwg or dxf files, when inserting pictures and spontaneously too on MAC Ventura for me…
Here is the apple crash log:
Translated Report (Full Report Below)
Process: QCAD-Pro [36505]
Path: /Applications/QCAD-Pro.app/Contents/MacOS/QCAD-Pro
Identifier: org.qcad
Version: 3.27 (3.27.6)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2022-12-19 15:25:41.3255 +0900
OS Version: macOS 13.1 (22C65)
Report Version: 12
Anonymous UUID: 29701D90-97DB-1E76-C2C8-341CB6F1FE3F
Sleep/Wake UUID: ABAF0454-CC18-4C6A-802F-83D23029CD96
Time Awake Since Boot: 91000 seconds
Time Since Wake: 4890 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes: 0x0000000000000001, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [36505]
VM Region Info: 0 is not in any region. Bytes before following region: 4374822912
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 104c28000-104c38000 [ 64K] r-x/r-x SM=COW …acOS/QCAD-Pro
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 QtScript 0x105c75b74 0x105c2c000 + 301940
1 QtScript 0x105c759e8 0x105c2c000 + 301544
2 QtScript 0x105c798a0 0x105c2c000 + 317600
3 QtScript 0x105cab650 0x105c2c000 + 521808
4 QtScript 0x105d1cb34 QScriptValue::call(QScriptValue const&, QList const&) + 628
5 libqcadecmaapi.dylib 0x106b060fc REcmaShellViewFocusListenerAdapter::updateFocus(RGraphicsView*) + 576
6 libqcadcore.dylib 0x105645224 RMainWindow::notifyViewFocusListeners(RGraphicsView*) + 356
7 libqcadgui.dylib 0x104d99520 RGraphicsViewQt::focusInEvent(QFocusEvent*) + 304
8 QtWidgets 0x107dbea84 QWidget::event(QEvent*) + 988
9 QtWidgets 0x107d894b0 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 292
10 QtWidgets 0x107d8a844 QApplication::notify(QObject*, QEvent*) + 556
11 QtCore 0x1095987e0 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 208
12 QtWidgets 0x107d8733c QApplicationPrivate::setFocusWidget(QWidget*, Qt::FocusReason) + 380
13 QtWidgets 0x107dba7d0 QWidget::setFocus(Qt::FocusReason) + 604
14 QtWidgets 0x107d8856c QApplication::setActiveWindow(QWidget*) + 1012
15 QtWidgets 0x107d88970 QApplicationPrivate::notifyActiveWindowChange(QWindow*) + 52
16 QtGui 0x1088b5b3c QGuiApplicationPrivate::processActivatedEvent(QWindowSystemInterfacePrivate::ActivatedWindowEvent*) + 612
17 QtGui 0x10889a3b0 void QWindowSystemInterface::handleWindowActivatedQWindowSystemInterface::SynchronousDelivery(QWindow*, Qt::FocusReason) + 168
18 libqcocoa.dylib 0x107ba0a5c 0x107b80000 + 133724
19 QtCore 0x1095a2fa0 QMetaMethod::invoke(QObject*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) const + 976
20 libqcocoa.dylib 0x107ba408c 0x107b80000 + 147596
21 CoreFoundation 0x1a1a3155c CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER + 128
22 CoreFoundation 0x1a1acf054 ___CFXRegistrationPost_block_invoke + 88
23 CoreFoundation 0x1a1acef9c _CFXRegistrationPost + 440
24 CoreFoundation 0x1a1a02b74 _CFXNotificationPost + 708
25 Foundation 0x1a28f072c -[NSNotificationCenter postNotificationName:object:userInfo:] + 88
26 AppKit 0x1a4e124bc -[NSWindow becomeKeyWindow] + 804
27 AppKit 0x1a4db7718 -[NSWindow _changeKeyAndMainLimitedOK:] + 748
28 AppKit 0x1a549ceac -[NSWindow _orderOut:calculatingKeyWithOptions:documentWindow:] + 884
29 AppKit 0x1a4cff528 NSPerformVisuallyAtomicChange + 108
30 AppKit 0x1a549e55c -[NSWindow _reallyDoOrderWindowOutRelativeTo:] + 488
31 AppKit 0x1a549e8a8 -[NSWindow _reallyDoOrderWindow:] + 80
32 AppKit 0x1a560ff4c -[NSSavePanel _reallyDoOrderWindow:] + 56
33 AppKit 0x1a549eaf8 -[NSWindow _doOrderWindow:] + 264
34 AppKit 0x1a560e398 -[NSSavePanel completeWithReturnCode:url:urls:] + 448
35 AppKit 0x1a560c9b4 -[NSSavePanel observeMostRecentCompletion:] + 464
36 AppKit 0x1a560c4a8 -[NSSavePanel observeValueForKeyPath:ofObject:change:context:] + 404
37 Foundation 0x1a291a3c4 NSKeyValueNotifyObserver + 252
38 Foundation 0x1a29ca280 NSKeyValueDidChange + 360
39 Foundation 0x1a2eb39f0 NSKeyValueDidChangeWithPerThreadPendingNotifications + 160
40 ViewBridge 0x1a95dd700 __47-[NSViewBridge setObject:forKey:withKVO:local:]block_invoke + 300
41 ViewBridge 0x1a9660200 withHintInProgress + 168
42 ViewBridge 0x1a95dd440 -[NSViewBridge setObject:forKey:withKVO:local:] + 532
43 ViewBridge 0x1a963fe74 -[NSRemoteViewMarshal setHostObject:forKey:] + 264
44 CoreFoundation 0x1a1a1edc4 invoking
+ 148
45 CoreFoundation 0x1a1a1ec3c -[NSInvocation invoke] + 428
46 ViewBridge 0x1a95d4bb4 __deferNSXPCInvocationOntoMainThread_block_invoke + 132
47 ViewBridge 0x1a95c9d44 __wrapBlockWithVoucher_block_invoke + 56
48 ViewBridge 0x1a965ef6c kNotRunningOnAppKitCompatibleThread_block_invoke + 360
49 CoreFoundation 0x1a1a3c5b0 CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK + 28
50 CoreFoundation 0x1a1a3c4c4 __CFRunLoopDoBlocks + 368
51 CoreFoundation 0x1a1a3b970 __CFRunLoopRun + 2452
52 CoreFoundation 0x1a1a3a888 CFRunLoopRunSpecific + 612
53 HIToolbox 0x1ab10ffa0 RunCurrentEventLoopInMode + 292
54 HIToolbox 0x1ab10fde4 ReceiveNextEventCommon + 672
55 HIToolbox 0x1ab10fb2c _BlockUntilNextEventMatchingListInModeWithFilter + 72
56 AppKit 0x1a4cbc424 _DPSNextEvent + 632
57 AppKit 0x1a4cbb5b4 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 728
58 AppKit 0x1a4ef5bdc -[NSApplication _doModalLoop:peek:] + 216
59 AppKit 0x1a4ef4aec __35-[NSApplication runModalForWindow:]_block_invoke_2 + 56
60 AppKit 0x1a4ef4a98 __35-[NSApplication runModalForWindow:]_block_invoke + 108
61 AppKit 0x1a4ef437c _NSTryRunModal + 100
62 AppKit 0x1a4ef423c -[NSApplication runModalForWindow:] + 292
63 AppKit 0x1a560b520 -[NSSavePanel runModal] + 340
64 libqcocoa.dylib 0x107bec900 0x107b80000 + 444672
65 libqcocoa.dylib 0x107bf0308 0x107b80000 + 459528
66 QtWidgets 0x107f61b08 QDialog::exec() + 264
67 libqtscript_widgets.dylib 0x1197209dc QtScriptShell_QFileDialog::exec() + 420
68 QtWidgets 0x107f633d4 0x107d78000 + 2012116
69 QtWidgets 0x107f635a8 QDialog::qt_metacall(QMetaObject::Call, int, void**) + 172
70 QtWidgets 0x107f7cf90 QFileDialog::qt_metacall(QMetaObject::Call, int, void**) + 32
71 QtScript 0x105d330e8 0x105c2c000 + 1077480
72 QtScript 0x105d31ad0 0x105c2c000 + 1071824
73 QtScript 0x105d23b50 0x105c2c000 + 1014608
74 QtScript 0x105d23498 0x105c2c000 + 1012888
75 QtScript 0x105c90284 0x105c2c000 + 410244
76 QtScript 0x105c75ac0 0x105c2c000 + 301760
77 QtScript 0x105c6e554 0x105c2c000 + 271700
78 QtScript 0x105d07168 0x105c2c000 + 897384
79 QtScript 0x105d0b0d8 QScriptEngine::evaluate(QString const&, QString const&, int) + 332
80 libqcadecmaapi.dylib 0x1060546b4 RScriptHandlerEcma::eval(QString const&, QString const&) + 44
81 libqcadecmaapi.dylib 0x106055e14 RScriptHandlerEcma::createActionApplicationLevel(QString const&, RGuiAction*) + 644
82 libqcadcore.dylib 0x10568c03c RScriptHandler::triggerActionApplicationLevel(QString const&, RGuiAction*) + 88
83 libqcadcore.dylib 0x105619458 RGuiAction::slotTrigger(QString const&) + 444
84 libqcadcore.dylib 0x10572dd30 RGuiAction::qt_static_metacall(QObject*, QMetaObject::Call, int, void**) + 168
85 QtCore 0x1095c8b78 0x1093c4000 + 2116472
86 QtWidgets 0x107d80348 QAction::activate(QAction::ActionEvent) + 308
87 QtWidgets 0x107e59694 0x107d78000 + 923284
88 QtWidgets 0x107e5a6dc QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 256
89 QtWidgets 0x107f47adc QToolButton::mouseReleaseEvent(QMouseEvent*) + 20
90 QtWidgets 0x107dbe728 QWidget::event(QEvent*) + 128
91 QtWidgets 0x107f481f8 QToolButton::event(QEvent*) + 280
92 QtWidgets 0x107d894b0 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 292
93 QtWidgets 0x107d8bdec QApplication::notify(QObject*, QEvent*) + 6100
94 QtCore 0x1095987e0 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 208
95 QtWidgets 0x107d89e28 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer&, bool, bool) + 988
96 QtWidgets 0x107ddc038 0x107d78000 + 409656
97 QtWidgets 0x107ddb058 0x107d78000 + 405592
98 QtWidgets 0x107d894b0 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 292
99 QtWidgets 0x107d8a844 QApplication::notify(QObject*, QEvent*) + 556
100 QtCore 0x1095987e0 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 208
101 QtGui 0x1088b3550 QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 2808
102 QtGui 0x108899428 QWindowSystemInterface::sendWindowSystemEvents(QFlagsQEventLoop::ProcessEventsFlag) + 248
103 libqcocoa.dylib 0x107bb7ee8 0x107b80000 + 229096
104 CoreFoundation 0x1a1a3ca18 CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION + 28
105 CoreFoundation 0x1a1a3c9ac __CFRunLoopDoSource0 + 176
106 CoreFoundation 0x1a1a3c71c __CFRunLoopDoSources0 + 244
107 CoreFoundation 0x1a1a3b320 __CFRunLoopRun + 836
108 CoreFoundation 0x1a1a3a888 CFRunLoopRunSpecific + 612
109 HIToolbox 0x1ab10ffa0 RunCurrentEventLoopInMode + 292
110 HIToolbox 0x1ab10fc30 ReceiveNextEventCommon + 236
111 HIToolbox 0x1ab10fb2c _BlockUntilNextEventMatchingListInModeWithFilter + 72
112 AppKit 0x1a4cbc424 _DPSNextEvent + 632
113 AppKit 0x1a4cbb5b4 -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 728
114 AppKit 0x1a4caf9e4 -[NSApplication run] + 464
115 libqcocoa.dylib 0x107bb6c40 0x107b80000 + 224320
116 QtCore 0x1095947a8 QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 524
117 QtCore 0x109598e10 QCoreApplication::exec() + 132
118 libqtscript_core.dylib 0x113d8822c qtscript_QCoreApplication_static_call(QScriptContext*, QScriptEngine*) + 1372
119 QtScript 0x105d1f6fc 0x105c2c000 + 997116
120 QtScript 0x105c90284 0x105c2c000 + 410244
121 QtScript 0x105c75ac0 0x105c2c000 + 301760
122 QtScript 0x105c6e554 0x105c2c000 + 271700
123 QtScript 0x105d07168 0x105c2c000 + 897384
124 QtScript 0x105d0b0d8 QScriptEngine::evaluate(QString const&, QString const&, int) + 332
125 libqcadecmaapi.dylib 0x1060546b4 RScriptHandlerEcma::eval(QString const&, QString const&) + 44
126 libqcadecmaapi.dylib 0x106053aa0 RScriptHandlerEcma::doScript(QString const&, QStringList const&) + 632
127 libqcadcore.dylib 0x10568bc38 RScriptHandler::init(QString const&, QStringList const&) + 1780
128 QCAD-Pro 0x104c35518 main + 4192
129 dyld 0x1a1633e50 start + 2544
Thread 1:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x1a1928a00 __select + 8
1 CoreFoundation 0x1a1a66344 __CFSocketManager + 636
2 libsystem_pthread.dylib 0x1a195d06c _pthread_start + 148
3 libsystem_pthread.dylib 0x1a1957e2c thread_start + 8
Thread 2:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x1a191dd70 mach_msg2_trap + 8
1 libsystem_kernel.dylib 0x1a192f8a4 mach_msg2_internal + 80
2 libsystem_kernel.dylib 0x1a19265c4 mach_msg_overwrite + 540
3 libsystem_kernel.dylib 0x1a191e0ec mach_msg + 24
4 CoreFoundation 0x1a1a3cbc0 __CFRunLoopServiceMachPort + 160
5 CoreFoundation 0x1a1a3b4ac __CFRunLoopRun + 1232
6 CoreFoundation 0x1a1a3a888 CFRunLoopRunSpecific + 612
7 AppKit 0x1a4de6410 _NSEventThread + 172
8 libsystem_pthread.dylib 0x1a195d06c _pthread_start + 148
9 libsystem_pthread.dylib 0x1a1957e2c thread_start + 8
Thread 3:: Qt bearer thread
0 libsystem_kernel.dylib 0x1a19262c0 poll + 8
1 QtCore 0x1095f5fa0 qt_safe_poll(pollfd*, unsigned int, timespec const*) + 436
2 QtCore 0x1095f77a0 QEventDispatcherUNIX::processEvents(QFlagsQEventLoop::ProcessEventsFlag) + 980
3 QtCore 0x1095947a8 QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag) + 524
4 QtCore 0x1093e3884 QThread::exec() + 136
5 QtCore 0x1093e4848 0x1093c4000 + 133192
6 libsystem_pthread.dylib 0x1a195d06c _pthread_start + 148
7 libsystem_pthread.dylib 0x1a1957e2c thread_start + 8
Thread 4:
0 libsystem_pthread.dylib 0x1a1957e18 start_wqthread + 0
Thread 5:
Thread 0 crashed with ARM Thread State (64-bit):
x0: 0x0000000000000002 x1: 0x000000016b1d0420 x2: 0x000000012e817838 x3: 0x000000016b1d02b8
x4: 0x0000000000000000 x5: 0x0000000000000074 x6: 0x0000000000000002 x7: 0x00000001113aca58
x8: 0x00000001149e61b8 x9: 0x000000000000000d x10: 0x000000012d9e61e0 x11: 0xffff000000000002
x12: 0x0000000000000010 x13: 0x0000000000000456 x14: 0x0000000000000456 x15: 0x000000012da57100
x16: 0x000000030e77809c x17: 0x00000001a17bce98 x18: 0x0000000000000000 x19: 0x0000000000000002
x20: 0x0000000000000002 x21: 0x000000000003e800 x22: 0x000000012e2a9a20 x23: 0x0000000000000002
x24: 0x0000000000000000 x25: 0x00000001131fda08 x26: 0x00000001131fda70 x27: 0x00000001149e6190
x28: 0xffff000000000002 fp: 0x000000016b1d0630 lr: 0x0000000105c759e8
sp: 0x000000016b1d0340 pc: 0x0000000105c75b74 cpsr: 0x20001000
far: 0x0000000000000000 esr: 0x92000006 (Data Abort) byte read Translation fault
Binary Images:
0x105c2c000 - 0x105d57fff org.qt-project.QtScript (5.15) <9c67824a-0c62-38b5-af36-d2273749b49d> /Applications/QCAD-Pro.app/Contents/Frameworks/QtScript.framework/Versions/5/QtScript
0x106014000 - 0x106f77fff libqcadecmaapi.dylib () <72f2ca88-3b5d-3d83-90a7-85588b2bf34e> /Applications/QCAD-Pro.app/Contents/Frameworks/libqcadecmaapi.dylib
0x105584000 - 0x10593ffff libqcadcore.dylib (
) <248220dc-4fbb-3410-8f10-3e8d42491469> /Applications/QCAD-Pro.app/Contents/Frameworks/libqcadcore.dylib
0x104d70000 - 0x104dbbfff libqcadgui.dylib () /Applications/QCAD-Pro.app/Contents/Frameworks/libqcadgui.dylib
0x107d78000 - 0x108183fff org.qt-project.QtWidgets (5.15) <4796d40a-2c12-3868-bdc4-f4dd2842e6f7> /Applications/QCAD-Pro.app/Contents/Frameworks/QtWidgets.framework/Versions/5/QtWidgets
0x1093c4000 - 0x10989bfff org.qt-project.QtCore (5.15) /Applications/QCAD-Pro.app/Contents/Frameworks/QtCore.framework/Versions/5/QtCore
0x108884000 - 0x108cebfff org.qt-project.QtGui (5.15) <065dfa63-76e8-3e06-b14c-f95cece5a413> /Applications/QCAD-Pro.app/Contents/Frameworks/QtGui.framework/Versions/5/QtGui
0x107b80000 - 0x107ccbfff libqcocoa.dylib (
) <2ae2783d-10bb-3477-8589-26977f29df63> /Applications/QCAD-Pro.app/Contents/PlugIns/platforms/libqcocoa.dylib
0x1a19bb000 - 0x1a1e92fff com.apple.CoreFoundation (6.9) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x1a28e7000 - 0x1a331ffff com.apple.Foundation (6.9) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x1a4c83000 - 0x1a5b8dfff com.apple.AppKit (6.9) /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x1a95c3000 - 0x1a96cafff com.apple.ViewBridge (695.2.2) <23cf5ded-761a-39a9-9f79-b7f245c333fd> /System/Library/PrivateFrameworks/ViewBridge.framework/Versions/A/ViewBridge
0x1ab0de000 - 0x1ab411fff com.apple.HIToolbox (2.1.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x1193d4000 - 0x119b8bfff libqtscript_widgets.dylib () <25e4b16f-1af6-3ade-bbc3-734349772fe2> /Applications/QCAD-Pro.app/Contents/PlugIns/script/libqtscript_widgets.dylib
0x113d5c000 - 0x113f4ffff libqtscript_core.dylib (
) /Applications/QCAD-Pro.app/Contents/PlugIns/script/libqtscript_core.dylib
0x104c28000 - 0x104c37fff org.qcad (3.27) <45c5128e-7ecc-378f-9f32-a364b3c18558> /Applications/QCAD-Pro.app/Contents/MacOS/QCAD-Pro
0x1a162e000 - 0x1a16b8b63 dyld () <487cfdeb-9b07-39bf-bfb9-970b61aea2d1> /usr/lib/dyld
0x1a191d000 - 0x1a1955ff3 libsystem_kernel.dylib (
) /usr/lib/system/libsystem_kernel.dylib
0x1a1956000 - 0x1a1962ffb libsystem_pthread.dylib (*) <132084c6-c347-3489-9ac2-fcaad21cdb73> /usr/lib/system/libsystem_pthread.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=1.3G resident=0K(0%) swapped_out_or_unallocated=1.3G(100%)
Writable regions: Total=1.3G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=1.3G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
CG backing stores 7104K 8
CG image 1232K 35
ColorSync 576K 29
CoreAnimation 640K 32
CoreGraphics 48K 3
CoreUI image data 4576K 33
Dispatch continuations 64.0M 1
Foundation 208K 3
JS VM Gigacage 20.8M 83
JS VM Isolated Heap 16.2M 4
Kernel Alloc Once 32K 1
MALLOC 1.0G 149
MALLOC guard page 192K 11
MALLOC_MEDIUM (reserved) 96.0M 1 reserved VM address space (unallocated)
STACK GUARD 56.1M 6
Stack 10.6M 6
VM_ALLOCATE 928K 40
WebKit Malloc 55.9M 68
__AUTH 1514K 293
__AUTH_CONST 18.5M 491
__CTF 756 1
__DATA 7883K 562
__DATA_CONST 30.2M 571
__DATA_DIRTY 1522K 178
__FONT_DATA 2352 1
__LINKEDIT 810.0M 77
__OBJC_CONST 3564K 253
__OBJC_RO 65.4M 1
__OBJC_RW 1986K 1
__TEXT 536.1M 585
dyld private memory 304K 3
mapped file 637.5M 104
shared memory 864K 14
TOTAL 3.4G 3651
TOTAL, minus reserved VM space 3.3G 3651
Full Report
{“app_name”:“QCAD-Pro”,“timestamp”:“2022-12-19 15:25:45.00 +0900”,“app_version”:“3.27”,“slice_uuid”:“45c5128e-7ecc-378f-9f32-a364b3c18558”,“build_version”:“3.27.6”,“platform”:1,“bundleID”:“org.qcad”,“share_with_app_devs”:1,“is_first_party”:0,“bug_type”:“309”,“os_version”:“macOS 13.1 (22C65)”,“roots_installed”:0,“name”:“QCAD-Pro”,“incident_id”:“1E7BF26A-D4B9-4A03-BF30-63A75C2C4C28”}
“uptime” : 91000,
“procRole” : “Foreground”,
“version” : 2,
“userID” : 501,
“deployVersion” : 210,
“modelCode” : “MacBookAir10,1”,
“coalitionID” : 17253,
“osVersion” : {
“train” : “macOS 13.1”,
“build” : “22C65”,
“releaseType” : “User”
“captureTime” : “2022-12-19 15:25:41.3255 +0900”,
“incident” : “1E7BF26A-D4B9-4A03-BF30-63A75C2C4C28”,
“pid” : 36505,
“translated” : false,
“cpuType” : “ARM-64”,
“roots_installed” : 0,
“bug_type” : “309”,
“procLaunch” : “2022-12-19 15:07:12.4854 +0900”,
“procStartAbsTime” : 2166173207890,
“procExitAbsTime” : 2192778449614,
“procName” : “QCAD-Pro”,
“procPath” : “/Applications/QCAD-Pro.app/Contents/MacOS/QCAD-Pro”,
“bundleInfo” : {“CFBundleShortVersionString”:“3.27”,“CFBundleVersion”:“3.27.6”,“CFBundleIdentifier”:“org.qcad”},
“storeInfo” : {“deviceIdentifierForVendor”:“E4642200-24C8-556D-8D1A-BC4DF23E2EF1”,“thirdParty”:true},
“parentProc” : “launchd”,
“parentPid” : 1,
“coalitionName” : “org.qcad”,
“crashReporterKey” : “29701D90-97DB-1E76-C2C8-341CB6F1FE3F”,
“throttleTimeout” : 2147483647,
“wakeTime” : 4890,
“sleepWakeUUID” : “ABAF0454-CC18-4C6A-802F-83D23029CD96”,
“sip” : “enabled”,
“vmRegionInfo” : “0 is not in any region. Bytes before following region: 4374822912\n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n—> \n __TEXT 104c28000-104c38000 [ 64K] r-x/r-x SM=COW …acOS/QCAD-Pro”,
“exception” : {“codes”:“0x0000000000000001, 0x0000000000000000”,“rawCodes”:[1,0],“type”:“EXC_BAD_ACCESS”,“signal”:“SIGSEGV”,“subtype”:“KERN_INVALID_ADDRESS at 0x0000000000000000”},
“termination” : {“flags”:0,“code”:11,“namespace”:“SIGNAL”,“indicator”:“Segmentation fault: 11”,“byProc”:“exc handler”,“byPid”:36505},
“vmregioninfo” : “0 is not in any region. Bytes before following region: 4374822912\n REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL\n UNUSED SPACE AT START\n—> \n __TEXT 104c28000-104c38000 [ 64K] r-x/r-x SM=COW …acOS/QCAD-Pro”,
“extMods” : {“caller”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“system”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“targeted”:{“thread_create”:0,“thread_set_state”:0,“task_for_pid”:0},“warnings”:0},
“faultingThread” : 0,
“threads” : [{“triggered”:true,“id”:1171611,“threadState”:{“x”:[{“value”:2},{“value”:6092031008},{“value”:5075204152},{“value”:6092030648},{“value”:0},{“value”:116},{“value”:2},{“value”:4584032856},{“value”:4640891320},{“value”:13},{“value”:5060321760},{“value”:18446462598732840962},{“value”:16},{“value”:1110},{“value”:1110},{“value”:5060784384},{“value”:13127614620},{“value”:7004212888,“symbolLocation”:0,“symbol”:“szone_try_free_default”},{“value”:0},{“value”:2},{“value”:2},{“value”:256000},{“value”:5069511200},{“value”:2},{“value”:0},{“value”:4615821832},{“value”:4615821936},{“value”:4640891280},{“value”:18446462598732840962}],“flavor”:“ARM_THREAD_STATE64”,“lr”:{“value”:4391918056},“cpsr”:{“value”:536875008},“fp”:{“value”:6092031536},“sp”:{“value”:6092030784},“esr”:{“value”:2449473542,“description”:“(Data Abort) byte read Translation fault”},“pc”:{“value”:4391918452,“matchesCrashFrame”:1},“far”:{“value”:0}},“queue”:“com.apple.main-thread”,“frames”:[{“imageOffset”:301940,“imageIndex”:0},{“imageOffset”:301544,“imageIndex”:0},{“imageOffset”:317600,“imageIndex”:0},{“imageOffset”:521808,“imageIndex”:0},{“imageOffset”:985908,“symbol”:“QScriptValue::call(QScriptValue const&, QList const&)”,“symbolLocation”:628,“imageIndex”:0},{“imageOffset”:11477244,“symbol”:“REcmaShellViewFocusListenerAdapter::updateFocus(RGraphicsView*)”,“symbolLocation”:576,“imageIndex”:1},{“imageOffset”:791076,“symbol”:“RMainWindow::notifyViewFocusListeners(RGraphicsView*)”,“symbolLocation”:356,“imageIndex”:2},{“imageOffset”:169248,“symbol”:“RGraphicsViewQt::focusInEvent(QFocusEvent*)”,“symbolLocation”:304,“imageIndex”:3},{“imageOffset”:289412,“symbol”:“QWidget::event(QEvent*)”,“symbolLocation”:988,“imageIndex”:4},{“imageOffset”:70832,“symbol”:“QApplicationPrivate::notify_helper(QObject*, QEvent*)”,“symbolLocation”:292,“imageIndex”:4},{“imageOffset”:75844,“symbol”:“QApplication::notify(QObject*, QEvent*)”,“symbolLocation”:556,“imageIndex”:4},{“imageOffset”:1918944,“symbol”:“QCoreApplication::notifyInternal2(QObject*, QEvent*)”,“symbolLocation”:208,“imageIndex”:5},{“imageOffset”:62268,“symbol”:“QApplicationPrivate::setFocusWidget(QWidget*, Qt::FocusReason)”,“symbolLocation”:380,“imageIndex”:4},{“imageOffset”:272336,“symbol”:“QWidget::setFocus(Qt::FocusReason)”,“symbolLocation”:604,“imageIndex”:4},{“imageOffset”:66924,“symbol”:“QApplication::setActiveWindow(QWidget*)”,“symbolLocation”:1012,“imageIndex”:4},{“imageOffset”:67952,“symbol”:“QApplicationPrivate::notifyActiveWindowChange(QWindow*)”,“symbolLocation”:52,“imageIndex”:4},{“imageOffset”:203580,“symbol”:“QGuiApplicationPrivate::processActivatedEvent(QWindowSystemInterfacePrivate::ActivatedWindowEvent*)”,“symbolLocation”:612,“imageIndex”:6},{“imageOffset”:91056,“symbol”:“void QWindowSystemInterface::handleWindowActivatedQWindowSystemInterface::SynchronousDelivery(QWindow*, Qt::FocusReason)”,“symbolLocation”:168,“imageIndex”:6},{“imageOffset”:133724,“imageIndex”:7},{“imageOffset”:1961888,“symbol”:“QMetaMethod::invoke(QObject*, Qt::ConnectionType, QGenericReturnArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument, QGenericArgument) const”,“symbolLocation”:976,“imageIndex”:5},{“imageOffset”:147596,“imageIndex”:7},{“imageOffset”:484700,“symbol”:“CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER”,“symbolLocation”:128,“imageIndex”:8},{“imageOffset”:1130580,“symbol”:“___CFXRegistrationPost_block_invoke”,“symbolLocation”:88,“imageIndex”:8},{“imageOffset”:1130396,“symbol”:“_CFXRegistrationPost”,“symbolLocation”:440,“imageIndex”:8},{“imageOffset”:293748,“symbol”:“_CFXNotificationPost”,“symbolLocation”:708,“imageIndex”:8},{“imageOffset”:38700,“symbol”:“-[NSNotificationCenter postNotificationName:object:userInfo:]”,“symbolLocation”:88,“imageIndex”:9},{“imageOffset”:1635516,“symbol”:“-[NSWindow becomeKeyWindow]”,“symbolLocation”:804,“imageIndex”:10},{“imageOffset”:1263384,“symbol”:“-[NSWindow _changeKeyAndMainLimitedOK:]”,“symbolLocation”:748,“imageIndex”:10},{“imageOffset”:8494764,“symbol”:“-[NSWindow _orderOut:calculatingKeyWithOptions:documentWindow:]”,“symbolLocation”:884,“imageIndex”:10},{“imageOffset”:509224,“symbol”:“NSPerformVisuallyAtomicChange”,“symbolLocation”:108,“imageIndex”:10},{“imageOffset”:8500572,“symbol”:“-[NSWindow _reallyDoOrderWindowOutRelativeTo:]”,“symbolLocation”:488,“imageIndex”:10},{“imageOffset”:8501416,“symbol”:“-[NSWindow _reallyDoOrderWindow:]”,“symbolLocation”:80,“imageIndex”:10},{“imageOffset”:10014540,“symbol”:“-[NSSavePanel _reallyDoOrderWindow:]”,“symbolLocation”:56,“imageIndex”:10},{“imageOffset”:8502008,“symbol”:“-[NSWindow _doOrderWindow:]”,“symbolLocation”:264,“imageIndex”:10},{“imageOffset”:10007448,“symbol”:“-[NSSavePanel completeWithReturnCode:url:urls:]”,“symbolLocation”:448,“imageIndex”:10},{“imageOffset”:10000820,“symbol”:“-[NSSavePanel observeMostRecentCompletion:]”,“symbolLocation”:464,“imageIndex”:10},{“imageOffset”:9999528,“symbol”:“-[NSSavePanel observeValueForKeyPath:ofObject:change:context:]”,“symbolLocation”:404,“imageIndex”:10},{“imageOffset”:209860,“symbol”:“NSKeyValueNotifyObserver”,“symbolLocation”:252,“imageIndex”:9},{“imageOffset”:930432,“symbol”:“NSKeyValueDidChange”,“symbolLocation”:360,“imageIndex”:9},{“imageOffset”:6081008,“symbol”:“NSKeyValueDidChangeWithPerThreadPendingNotifications”,“symbolLocation”:160,“imageIndex”:9},{“imageOffset”:108288,“symbol”:“__47-[NSViewBridge setObject:forKey:withKVO:local:]block_invoke",“symbolLocation”:300,“imageIndex”:11},{“imageOffset”:643584,“symbol”:“withHintInProgress”,“symbolLocation”:168,“imageIndex”:11},{“imageOffset”:107584,“symbol”:“-[NSViewBridge setObject:forKey:withKVO:local:]”,“symbolLocation”:532,“imageIndex”:11},{“imageOffset”:511604,“symbol”:“-[NSRemoteViewMarshal setHostObject:forKey:]”,“symbolLocation”:264,“imageIndex”:11},{“imageOffset”:409028,“symbol”:"invoking”,“symbolLocation”:148,“imageIndex”:8},{“imageOffset”:408636,“symbol”:“-[NSInvocation invoke]”,“symbolLocation”:428,“imageIndex”:8},{“imageOffset”:72628,“symbol”:“__deferNSXPCInvocationOntoMainThread_block_invoke”,“symbolLocation”:132,“imageIndex”:11},{“imageOffset”:27972,“symbol”:“__wrapBlockWithVoucher_block_invoke”,“symbolLocation”:56,“imageIndex”:11},{“imageOffset”:638828,“symbol”:“kNotRunningOnAppKitCompatibleThread_block_invoke”,“symbolLocation”:360,“imageIndex”:11},{“imageOffset”:529840,“symbol”:“CFRUNLOOP_IS_CALLING_OUT_TO_A_BLOCK”,“symbolLocation”:28,“imageIndex”:8},{“imageOffset”:529604,“symbol”:“__CFRunLoopDoBlocks”,“symbolLocation”:368,“imageIndex”:8},{“imageOffset”:526704,“symbol”:“__CFRunLoopRun”,“symbolLocation”:2452,“imageIndex”:8},{“imageOffset”:522376,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:612,“imageIndex”:8},{“imageOffset”:204704,“symbol”:“RunCurrentEventLoopInMode”,“symbolLocation”:292,“imageIndex”:12},{“imageOffset”:204260,“symbol”:“ReceiveNextEventCommon”,“symbolLocation”:672,“imageIndex”:12},{“imageOffset”:203564,“symbol”:“_BlockUntilNextEventMatchingListInModeWithFilter”,“symbolLocation”:72,“imageIndex”:12},{“imageOffset”:234532,“symbol”:“_DPSNextEvent”,“symbolLocation”:632,“imageIndex”:10},{“imageOffset”:230836,“symbol”:“-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]”,“symbolLocation”:728,“imageIndex”:10},{“imageOffset”:2567132,“symbol”:“-[NSApplication _doModalLoop:peek:]”,“symbolLocation”:216,“imageIndex”:10},{“imageOffset”:2562796,“symbol”:“__35-[NSApplication runModalForWindow:]_block_invoke_2”,“symbolLocation”:56,“imageIndex”:10},{“imageOffset”:2562712,“symbol”:“__35-[NSApplication runModalForWindow:]_block_invoke”,“symbolLocation”:108,“imageIndex”:10},{“imageOffset”:2560892,“symbol”:“_NSTryRunModal”,“symbolLocation”:100,“imageIndex”:10},{“imageOffset”:2560572,“symbol”:“-[NSApplication runModalForWindow:]”,“symbolLocation”:292,“imageIndex”:10},{“imageOffset”:9995552,“symbol”:“-[NSSavePanel runModal]”,“symbolLocation”:340,“imageIndex”:10},{“imageOffset”:444672,“imageIndex”:7},{“imageOffset”:459528,“imageIndex”:7},{“imageOffset”:2005768,“symbol”:“QDialog::exec()”,“symbolLocation”:264,“imageIndex”:4},{“imageOffset”:3459548,“symbol”:“QtScriptShell_QFileDialog::exec()”,“symbolLocation”:420,“imageIndex”:13},{“imageOffset”:2012116,“imageIndex”:4},{“imageOffset”:2012584,“symbol”:“QDialog::qt_metacall(QMetaObject::Call, int, void**)”,“symbolLocation”:172,“imageIndex”:4},{“imageOffset”:2117520,“symbol”:“QFileDialog::qt_metacall(QMetaObject::Call, int, void**)”,“symbolLocation”:32,“imageIndex”:4},{“imageOffset”:1077480,“imageIndex”:0},{“imageOffset”:1071824,“imageIndex”:0},{“imageOffset”:1014608,“imageIndex”:0},{“imageOffset”:1012888,“imageIndex”:0},{“imageOffset”:410244,“imageIndex”:0},{“imageOffset”:301760,“imageIndex”:0},{“imageOffset”:271700,“imageIndex”:0},{“imageOffset”:897384,“imageIndex”:0},{“imageOffset”:913624,“symbol”:“QScriptEngine::evaluate(QString const&, QString const&, int)”,“symbolLocation”:332,“imageIndex”:0},{“imageOffset”:263860,“symbol”:“RScriptHandlerEcma::eval(QString const&, QString const&)”,“symbolLocation”:44,“imageIndex”:1},{“imageOffset”:269844,“symbol”:“RScriptHandlerEcma::createActionApplicationLevel(QString const&, RGuiAction*)”,“symbolLocation”:644,“imageIndex”:1},{“imageOffset”:1081404,“symbol”:“RScriptHandler::triggerActionApplicationLevel(QString const&, RGuiAction*)”,“symbolLocation”:88,“imageIndex”:2},{“imageOffset”:611416,“symbol”:“RGuiAction::slotTrigger(QString const&)”,“symbolLocation”:444,“imageIndex”:2},{“imageOffset”:1744176,“symbol”:“RGuiAction::qt_static_metacall(QObject*, QMetaObject::Call, int, void**)”,“symbolLocation”:168,“imageIndex”:2},{“imageOffset”:2116472,“imageIndex”:5},{“imageOffset”:33608,“symbol”:“QAction::activate(QAction::ActionEvent)”,“symbolLocation”:308,“imageIndex”:4},{“imageOffset”:923284,“imageIndex”:4},{“imageOffset”:927452,“symbol”:“QAbstractButton::mouseReleaseEvent(QMouseEvent*)”,“symbolLocation”:256,“imageIndex”:4},{“imageOffset”:1899228,“symbol”:“QToolButton::mouseReleaseEvent(QMouseEvent*)”,“symbolLocation”:20,“imageIndex”:4},{“imageOffset”:288552,“symbol”:“QWidget::event(QEvent*)”,“symbolLocation”:128,“imageIndex”:4},{“imageOffset”:1901048,“symbol”:“QToolButton::event(QEvent*)”,“symbolLocation”:280,“imageIndex”:4},{“imageOffset”:70832,“symbol”:“QApplicationPrivate::notify_helper(QObject*, QEvent*)”,“symbolLocation”:292,“imageIndex”:4},{“imageOffset”:81388,“symbol”:“QApplication::notify(QObject*, QEvent*)”,“symbolLocation”:6100,“imageIndex”:4},{“imageOffset”:1918944,“symbol”:“QCoreApplication::notifyInternal2(QObject*, QEvent*)”,“symbolLocation”:208,“imageIndex”:5},{“imageOffset”:73256,“symbol”:“QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer&, bool, bool)”,“symbolLocation”:988,“imageIndex”:4},{“imageOffset”:409656,“imageIndex”:4},{“imageOffset”:405592,“imageIndex”:4},{“imageOffset”:70832,“symbol”:“QApplicationPrivate::notify_helper(QObject*, QEvent*)”,“symbolLocation”:292,“imageIndex”:4},{“imageOffset”:75844,“symbol”:“QApplication::notify(QObject*, QEvent*)”,“symbolLocation”:556,“imageIndex”:4},{“imageOffset”:1918944,“symbol”:“QCoreApplication::notifyInternal2(QObject*, QEvent*)”,“symbolLocation”:208,“imageIndex”:5},{“imageOffset”:193872,“symbol”:“QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*)”,“symbolLocation”:2808,“imageIndex”:6},{“imageOffset”:87080,“symbol”:“QWindowSystemInterface::sendWindowSystemEvents(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:248,“imageIndex”:6},{“imageOffset”:229096,“imageIndex”:7},{“imageOffset”:530968,“symbol”:“CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION”,“symbolLocation”:28,“imageIndex”:8},{“imageOffset”:530860,“symbol”:“__CFRunLoopDoSource0”,“symbolLocation”:176,“imageIndex”:8},{“imageOffset”:530204,“symbol”:“__CFRunLoopDoSources0”,“symbolLocation”:244,“imageIndex”:8},{“imageOffset”:525088,“symbol”:“__CFRunLoopRun”,“symbolLocation”:836,“imageIndex”:8},{“imageOffset”:522376,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:612,“imageIndex”:8},{“imageOffset”:204704,“symbol”:“RunCurrentEventLoopInMode”,“symbolLocation”:292,“imageIndex”:12},{“imageOffset”:203824,“symbol”:“ReceiveNextEventCommon”,“symbolLocation”:236,“imageIndex”:12},{“imageOffset”:203564,“symbol”:“_BlockUntilNextEventMatchingListInModeWithFilter”,“symbolLocation”:72,“imageIndex”:12},{“imageOffset”:234532,“symbol”:“_DPSNextEvent”,“symbolLocation”:632,“imageIndex”:10},{“imageOffset”:230836,“symbol”:“-[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:]”,“symbolLocation”:728,“imageIndex”:10},{“imageOffset”:182756,“symbol”:“-[NSApplication run]”,“symbolLocation”:464,“imageIndex”:10},{“imageOffset”:224320,“imageIndex”:7},{“imageOffset”:1902504,“symbol”:“QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:524,“imageIndex”:5},{“imageOffset”:1920528,“symbol”:“QCoreApplication::exec()”,“symbolLocation”:132,“imageIndex”:5},{“imageOffset”:180780,“symbol”:“qtscript_QCoreApplication_static_call(QScriptContext*, QScriptEngine*)”,“symbolLocation”:1372,“imageIndex”:14},{“imageOffset”:997116,“imageIndex”:0},{“imageOffset”:410244,“imageIndex”:0},{“imageOffset”:301760,“imageIndex”:0},{“imageOffset”:271700,“imageIndex”:0},{“imageOffset”:897384,“imageIndex”:0},{“imageOffset”:913624,“symbol”:“QScriptEngine::evaluate(QString const&, QString const&, int)”,“symbolLocation”:332,“imageIndex”:0},{“imageOffset”:263860,“symbol”:“RScriptHandlerEcma::eval(QString const&, QString const&)”,“symbolLocation”:44,“imageIndex”:1},{“imageOffset”:260768,“symbol”:“RScriptHandlerEcma::doScript(QString const&, QStringList const&)”,“symbolLocation”:632,“imageIndex”:1},{“imageOffset”:1080376,“symbol”:“RScriptHandler::init(QString const&, QStringList const&)”,“symbolLocation”:1780,“imageIndex”:2},{“imageOffset”:54552,“symbol”:“main”,“symbolLocation”:4192,“imageIndex”:15},{“imageOffset”:24144,“symbol”:“start”,“symbolLocation”:2544,“imageIndex”:16}]},{“id”:1171642,“name”:“com.apple.CFSocket.private”,“frames”:[{“imageOffset”:47616,“symbol”:“__select”,“symbolLocation”:8,“imageIndex”:17},{“imageOffset”:701252,“symbol”:“__CFSocketManager”,“symbolLocation”:636,“imageIndex”:8},{“imageOffset”:28780,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:18},{“imageOffset”:7724,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:18}]},{“id”:1171652,“name”:“com.apple.NSEventThread”,“frames”:[{“imageOffset”:3440,“symbol”:“mach_msg2_trap”,“symbolLocation”:8,“imageIndex”:17},{“imageOffset”:75940,“symbol”:“mach_msg2_internal”,“symbolLocation”:80,“imageIndex”:17},{“imageOffset”:38340,“symbol”:“mach_msg_overwrite”,“symbolLocation”:540,“imageIndex”:17},{“imageOffset”:4332,“symbol”:“mach_msg”,“symbolLocation”:24,“imageIndex”:17},{“imageOffset”:531392,“symbol”:“__CFRunLoopServiceMachPort”,“symbolLocation”:160,“imageIndex”:8},{“imageOffset”:525484,“symbol”:“__CFRunLoopRun”,“symbolLocation”:1232,“imageIndex”:8},{“imageOffset”:522376,“symbol”:“CFRunLoopRunSpecific”,“symbolLocation”:612,“imageIndex”:8},{“imageOffset”:1455120,“symbol”:“_NSEventThread”,“symbolLocation”:172,“imageIndex”:10},{“imageOffset”:28780,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:18},{“imageOffset”:7724,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:18}]},{“id”:1171674,“name”:“Qt bearer thread”,“frames”:[{“imageOffset”:37568,“symbol”:“poll”,“symbolLocation”:8,“imageIndex”:17},{“imageOffset”:2301856,“symbol”:“qt_safe_poll(pollfd*, unsigned int, timespec const*)”,“symbolLocation”:436,“imageIndex”:5},{“imageOffset”:2308000,“symbol”:“QEventDispatcherUNIX::processEvents(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:980,“imageIndex”:5},{“imageOffset”:1902504,“symbol”:“QEventLoop::exec(QFlagsQEventLoop::ProcessEventsFlag)”,“symbolLocation”:524,“imageIndex”:5},{“imageOffset”:129156,“symbol”:“QThread::exec()”,“symbolLocation”:136,“imageIndex”:5},{“imageOffset”:133192,“imageIndex”:5},{“imageOffset”:28780,“symbol”:“_pthread_start”,“symbolLocation”:148,“imageIndex”:18},{“imageOffset”:7724,“symbol”:“thread_start”,“symbolLocation”:8,“imageIndex”:18}]},{“id”:1183764,“frames”:[{“imageOffset”:7704,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:18}]},{“id”:1183807,“frames”:[{“imageOffset”:7704,“symbol”:“start_wqthread”,“symbolLocation”:0,“imageIndex”:18}]}],
“usedImages” : [
had to cut some part from here…
