Write Script to Change Color of a Line
I don’t have much experience writing JavaScipt for QCAD - although about 10 years ago I was writing quite a lot of JavaScript (for websites).
I’m kludging together code. I’m using the following code (which works fine):
addLine(x0, y0, x1, y1);
Where the variables are the desired coordinates.
I’d like to also change the color of the line as they are drawn. Would the following code be suitable?
RColor(r,g,b);
I’ve tried using RColor() but got some kind of error (shown below)
Script exception in script 'C:/<path>/spiral_trace.js': Error: :-1:-1: RColor(): Did you forget to construct with 'new'? <native>(23, 165, 231) at -1 anonymous() at 31 <anonymous>() at :scripts/Misc/MiscDevelopment/RunScript/RunScript.js:120 <eval>() at 1 <native>() at -1 main() at :scripts\autostart.js:826 <global>() at :scripts\autostart.js:839
From the error message - I guess I didn’t " construct with ‘new’ "
So, what does that mean?
How do I “construct with new”?
Perhaps a example code showing typical use of RColor() would help. QCAD documentation was overwhelming. Searching “color” here yielded the haystack instead of the needle I was looking for.
I’m using QCAD version 3.24.3.0 (3.24.3) and Windows 11 Pro.
Thanks!
HS
Is part of the Simple API.
This doesn’t allow for additional properties.
One could first set the current pen color with: setCurrentColor(…)
And/or the layer: setCurrentLayer(…)
But not the Linetype.
Another option is to use the full QCAD API
Note that most QCAD tools are implemented as scripts.
Meaning that there is a vast collection of example scripts. :wink:
